i am trying to get a few people together to have a lil r/c meet at monash uni.
so far i have a few people from rcdrift.org, nissansilvia.com and eurocca.net aswell
car park is approx 130x60m with only 3 poles in the way.
i hope this turns out to be a good social event where we can relax, drive and have a good time.
meet time is approx 2pm and will run till whenever.!!!
anyone interested???
https://www.sau.com.au/forums/topic/82779-rc-drift-meet-at-monash-uni-clayton/
Dude are you for real?
Whats the deal with the cops and allowing 50 people to use a uni car park for drifting? neighbours complaining and shit?
Damn Hooligans.
ofcourse his 4real, these things go on all the time, dont be suprised
should be legal rite? its remote controlled car drifting if im not mistaken??
can i invite my lil bro? he's a pretty good drifing maggot who goes on n on n on abt how good he is... i told him to get a rwd car n then talk hahaha
btw, the car park i assume where this event is taking place is the engineering carpark? how abt a decent description of the place :unsure:
pleasae take note that 20vturbo stated "r/c" meet and taking that r/c means recmote controlled this is for 1/18th scale cars! NOT NORMAL ROAD GOING CARS!! and the university does not endorse drifting or any other such degenerate actions on its premesis (just dont let em know... B))
I used to race Radio Controlled Cars at the track over at Templestowe Reserve. Before it got all re-done.
I raced a Tamiya 4WD, Celica it was. Had it ball raced, electronic speed control and used to only ever loos to a guy who had one extra ball bearing in the car, the big one near the motor.
Loved it!
Sold the car and all the bits to buy an exhaust for my first Commodore. VN V6 5 speed!
So that's where it all started!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
