Hi Guys, i have an Alpine IVA-D310E for sale. It hasnt been powered up, 100% new condition and also has been unlocked so it will play imported dvd's. I would prefer pickup in WA, however can post at buyers cost (around $45 for insured postage)
Here are the specs
• PulseTouch™ Display
• 7" Fully Motorized Monitor
• White LED Sub Display
• 50W MAX x 4/18W RMS x 4 High Power Amplifier
• Dolby Digital/DTS Decoder Ready
• DVD-R/RW Compatible
• MP3 and WMA Playback
• MP3 ID3 Tag Informationo Ready for iPod (KCA-420i)
• Satellite Radio Ready
• DVD Menu Direct Touch Control
• iPersonalize™ Data Download
• Amplifier Link, Bass Engine™
• Visual Equalizer
• 3 PreOuts
• Rear Camera Input
• Navigation Input
• 1 A/V Input
• 1 A/V Output
• Navi Mixo MediaXpander
• PXA-H701/MRA-D550/MRD-F350 Touch Control Ready
• Audio Signal Loop Ready
• Anti-Theft Detachable Face
Pictures on request
I purchased this for $2550 just 1 month ago, but due to financial difficulties i need to sell. Im happy to let it go at $2200 ono. Warranty is still available aswell, i will provide the original receipt upon inspection.
Cheers
https://www.sau.com.au/forums/topic/82784-fs-alpine-dvd-player/
what are the differences with the older iva d300e model?
It improves on a few important areas over the 300E including additional functionality with the screen closed and improved touchscreen functions. Also the lack of secondary display on the front panel and other buttons so that the unit can work as per a regular CD tuner when the screen is closed
  • 5 weeks later...
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
