Hey ppl ,
just put in the new SARD 550cc side feed injectors and i noticed that the caps from the standard injectors do not fit over them so i installed the injectors without them on ..
just double checking to see if this will affect anything...
are they required for use or can i leave the caps off..??
Chris
https://www.sau.com.au/forums/topic/82810-injector-install/
If you are talking about the cap with the 2 screws you may need to remove the small plastic/rubber bit in the top of the cap to clear the top of the injector. I dont have these in mine and haven't had a problem.
If you are talking about the machined alloy ring that sards need to seal than you may have an issue.
https://www.sau.com.au/forums/topic/82810-injector-install/#findComment-1500408
Hi guys.... collars came with them and they are bolted in ok ..
what i was refering too was the cap that hold the original injectors in. what BHDave was refering too!
and if your going ok with the caps/covers i wont worry about putting them on now!
https://www.sau.com.au/forums/topic/82810-injector-install/#findComment-1500924
