Guys, my car got stolen off my driveway a few days ago. Please keep a look out for me. Its a black 1992 180sx, tinted windows, lowered and black leather seats, otherwise all stock. its got slight front passenger side paint damage on the front bumper and there is a line of paint missing on the rear bumper
Reward of $1000 for info that leads to recovering it
Pics
http://www.nissansilvia.com/forums/index.p...howtopic=103667
Info: 0431623102
Dean
https://www.sau.com.au/forums/topic/82818-stolen-180sx-yie-502-black/
What off your driveway??? Man these ppl should be killed.. Sorry 2 be so rude, but really shits me when i hear this..
Hmm where abouts do you live mate?? Will keep a look out..
Hmm try also postin in nissan silvia forums..
Pics
thanks for the help guys, really need it back cause i didnt have insurance
Beats me how they took it
no broken glass and the neighbours said they heard the alarm deactivate like it does when u press the remote, sus ay
neways thanks guys, eyes open
damn sorry to hear man nice car gone by some little poor bastards that cant get there own sorry but it shits me so much when little pricks do this sort of thing then to do it so good that you dont even know how they took it it even worse.....
  • 3 weeks later...
    • I should try the experiment you're talking about, the throttle switch is still there carried over from the R32 and it's still all wired up but after I did the whole intake manifold refurb and had to recalibrate the TPS I managed to somehow get the idle switch reporting activation at 0.22V, then when I adjusted it to 0.45V for idle it decided the engine was permanently no longer idling which caused some very weird behavior, closed loop idle was disabled so it would basically be at the whims of the cold start valve and whatever the base timing table was at. Then just unplugging/replugging the TPS with the ECU live caused it to relearn the idle TPS position and decide 0.45V was idle. Presumably there's nothing in the TPS that allows for the throttle switch to "recalibrate" like that, not easily at least.
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
