Hey guys. Just wondering if any of you would have any information on the best place to find a set of coils packs for my car. R32GTS-t RB20
It's cutting under boost, at first I thought it was AF Sensor, but at closer examination from a number of us, we believe it's the coils. Or if you guys have any ideas??
Nothing worse than wanting power and all you get is spurts and blurts!!
I've had a brief look on the forums but have found diddely.
I am in Melbourne so any info would be greatly appreciated.
Thanks
Sava
Fulllock Motorsport
https://www.sau.com.au/forums/topic/82828-coil-packs-for-an-rb20/
Also, could depend on the amount of boost you are using. Your gap in the spark plugs might be too large, so if you are running higher boost you might be blowing out the spark. If you havent already get some 0.8mm gapped plugs, it worked for me.
I'm running just on 1bar. Not too sure if this is enough to warrant having that problem.
How much were you running? And what spark plugs did you use?
Cheers
    • Ahhh, that, yeah, but it all worked out well in the end As for the ITB noises, I don't really wind it out with her in the car, and the dort only really starts dorting hard when your WOT or up it hard
    • It wasn't about the dollars. I mean how she didn't like the loud exhaust and you had to change it again 😛
    • I'll tell her I put in a new air filter on it, which, it would have anyway with the ITB's In the end she isn't to fussed, she spends lots of money on hair, nails, make-up and all the other "required" beauty products that women use, plus I grease the wheels with shiny gifts and holidays wherever and whenever I can She once questioned my car spending "budget", but after itemising everything she spends on herself, and what I spend on her, and the fact that I don't care if she does or doesn't wear make-up and fancy pants perfume, or requires new outfits for every wedding, funeral or anything else she deems worthy, and I'm quite happy to go "real" camping, instead of staying in hotels or jaunts on cruise ships, she decided not to press the subject on how I spend funds, and has never asked "how much did that cost" again, so a win to me And how often can you say you really get a win with the fairer sex? She is a good woman, and in the big picture, I'm really lucky.....that she hasn't killed me yet
    • What will you do when the Minister of War and Finance says the intake noises are too loud?
    • Will the clear coat dissolve the ink tho?? I thought about clear vinyl tape too. Thinking what to do haha. The one I have now is cracked in 1 spot, otherwise mint. Plus the MINES one is much thicker plastic material so its not flimsy at all.
