I have 2 plugs near my O2 sensor. One or both of which may or may not lead back to the ECU.
Anyways, other than using a multimeter, which I don't have. Is there a way to tell which one is actually the right plug, so I can get rid of the other.
I've had both of them plugged inone at a time on the dyno and it didn't make any difference.
Thanks.
It wont make a difference on the dyno. If you have the wrong one plugged in you will get very bad fuel economy. Do you have a consult connector?
maybe try plugging one in for a tank of fuel then the other for the next tank and see how many k's you get from each.
it's there to lean it off when cruising, does nothing when accelerating.
Nissans are usually set up so that 2 plugs close to each other can't accidentally be connected to the wrong sensor. If both plugs can be connected to the O2 sensor, then probably neither should be connected.
