hey
funkymonkey posted a good el cheapo rev limiter which had dual stage and some crazy fuel cut method or something, cant recall exactly. do a search on bee-r or beer rev limiter or maybe bee-r powerfc rev limit and you should find it, about 6 months ago ish
If it was me I would use the clutch.
As you are going to want the lower level for launching you could have a push in switch when the pedal is all the way depressed having the lower limit and once off and running it will be constantly on the high setting.
Would eliminate having to think about it and give more concentration on other things, and dismiss any chance of forgetting to switch it or not switching it properley.
