Drift Day At Collie An Alternative
Steve
 Share
No he didnt, I asked about october, but he said he couldnt say as he (Jay) was told there is no proposed date for completion, just that it will get done when it gets done.
Bit of a shame, might have to move back east :D
Edited by Steve
  • Replies 116
GOd dang, i was so looking forward to drifting at Collie
Oh wells, is kinda good cos my car is rooted and needs repairs
At least now i wont rush them hoping to get it back on the road before the 10th
Let us know when this can be reorganised
Am very kean to lend a hand in organising it at a later date
Thanks guys, I definately havent given up on the idea of getting a track day going, ideally I would like to see regular practice sessions available.
Will let you all know when it happens for sure.
Paul, nah, I didnt move back here for drift. Just depressing when you cant do something you love doing :D
  • 3 weeks later...
Fantastic night apart from the moment when I got bogged on the hairpin at the top of the hill and when I spun out of the final corner and almost hit the wall on the opposite side. I was pretty pleased with my effort as a first timer. But the rest of the night was great. There was a lot of media there. Are we going to see pictures/video's sometime soon?
Here's my photos from the night... Not sure how many other people were signed on as media.. I only saw Furious Imports filming (plus myself taking photos)
http://www.highoctanephotos.com/index.php?...bnails&album=42
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
