As anyone here installed titanium exhaust systems, most preferably Cat back!!
Its worth about 200 bucks more than normal stainless or whateva, but is it really worth it??
Also maybe titanium for dump/front pipe, but im yet to find a twin split pipe in titanium..
BUt i wanna know your opinions and if anyone has installed one..
So basically i just need some feedback..
Ohh the car is for series 2 r33..
Thanks..
https://www.sau.com.au/forums/topic/82903-titanium-exhaust-system/
Thanks..
i got a full exhaust on my r33 series 2, heres what i did and heres what i found. the jap brand exhaust and titanium dont mean much at all and probably just adds to the cost. your local exhaust shop can probably fit and supply a 3" exhaust for about $1100ish. should include a 3" hiflow cat. then you just need a suitable split dump pipe. batmbl can sell a 3" twin split dump pipe for $400 which connects to the cat. the exhaust place should be able to fit this for you and it should end up costing about $1400 total fitted for 3" twin split dump and 3" hiflow cat and exhaust.
most jap brands are $1300ish delivered then you have to fit it and then get a dump pipe as well. so all in all ask your local exhaust shop for a price to:
supply + fit 3" cat back system with hi flow cat
fit 3" split dump pipe to suit turbo flange and connects to cat
Titanium exhausts are overkill IMO and are only good for vehicles trying to attain an exhaust that can withstand massive amounts of heat (ie. in drag, track vehciles) and wish to lighten there car. It will only lighten it by about 2-5kg over stainless steel so I wouldn't bother.
Save your $200 and spend it on something else.
actually you'll find a mild steel / stainless steel exhaust will weigh in the region of 20+ kilos, whereas a titanium system will be in the region of 8 - 10...
They've come down in price a lot:
http://www.skylinesaustralia.com/forums/in...showtopic=82023
LW.
Ok I know its not a Skyline but my CBR600 came with a titanium exhaust fitted from the previous owner (it cost $1000).
Main advantages to me:
1) It is extremley light weight and therfore enhances power/weight ratio and cornering.
2) It DOESN'T get hot AT ALL - which means I don't burn anything when I touch it.
I have a veilside teardrop titanium cat back exhaust for a R34 GTR weights 4.2 kg (standard GTR exhuast is 18kg) it is one of the lightest on the market it is around 3 1/2 inches has no resonator and is a one piece exhaust. Have heard one on a R33 GTR wasn't droney or overly loud they dont seem to be that well known amongst the skyline community but are the exhaust to have amongst alot of the supra boys in the US.
Its not that the Vileside (whoops, bad habit ;)) teardrop exhausts aren't 'known', its that most of use aren't made of out gold. Even titanium exhausts from the less exclusive Japanese manufactures like Trust are expensive let alone those from companies like Vileside, Amuse, Fujitsubo or god forbid ARC.
Its a shame Rezz didn't continue his little commercial venture as he had access to some of the second tier companies that made titanium exhausts.
I payed $1150 for it delivered out of japan to sydney and about another $80 to get it up to townsville thats cheaper then most stainless systems
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
