He spent your cash, thats the real reason he wont give it back.
He doesnt have it.
Next time use a jap exporter, dont use any brokers and dont pay any broker fees.
whats this??
who does all the paper work for ya?
who complies the ride?
would be very interested to know
search the forum, these have been answered quite a few times. tdawg in particular is a proponent of DIYing the import process.
in a way, he's right. you assume the role of the broker and handle all the paperwork. obviously someone else ships the car, someone else complies the car, etc.
like just about any middleman, you can do their job if you have time and resources. i went with a broker on both of my imports and probably will on the next one too, simply because they have the contacts and the reputation to lose.
have a search on the forum for stories of uncompliable imports that have to be re-exported or destroyed. sobering.
So what’s the difference between you importing directly off the jap exporter or your broker importing off the exact same jap exporter on your behalf?
It costs you $1000 extra?
Exactly the same results and risks?
The amount of paperwork is almost nothing, you fill out a form or two and you email or fax another form or two. Your compliancer and customs broker will be doing most of the paperwork.
On one hand it makes me sad that after using a broker twice you don’t have the sense to not use one, if there is a third import.
On the other hand its people like you that make people with a bit of common sense, blinging rich. When I get out of uni I will need your dollars :D
Cheers
Edited by tdawg
tdawg whilst I'm sure a lot of us agree that taking the time to cut out some steps in the import process can go a long way towards saving money, we don't need to see this in every single thread in the imports section..
Vijay
We don’t? Who are we? Are you trying to say that you and everyone else on this forum are a group who have the same opinion?
I see posts constantly from people who think paying some import broker in Australia is the only, or best way to get a car here.
Look three posts up from yours and you will see one.
Edited by tdawg
On the other hand its people like you that make people with a bit of common sense, blinging rich. When I get out of uni I will need your dollars  ;)
oi cripes a uni student!!! got a quote for us, have ya??
i thought i put your case fairly well in my post, but when you come out guns blazing and pants around your ankles, it makes you look like a twit.
ugh, work it out tdawg.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
