HICAS is good at high speed along the freeway, but at low speeds and general cornering and flicking the ass out I'm finding that I just don't like how it behaves. Going on other people's comments that's not too uncommon. I wanna slide sideways damnit!
It's quite strange - very different to any other RWD i have driven and i think i've decided over the last few weeks i don't like and want to waste some more tyre :D
I did a bit of a search but not too much in terms of how to remove it. I jacked up the car the other day and found it was a lot more accessible than I thought, just sticking out there little motor behind the rear axle.
Now, can I simply pull out the elec. plugs and that will disable it or is it more complicated than that? I have seen separate HICAS lock kits - where abouts can i find these and are these essential?
For short term i'm happy to do a quick and dirty fix (and just remove elec connections) as long as it works. Longer term if I can do a proper solution and get a locking kit??
Thanx in advance
https://www.sau.com.au/forums/topic/8292-removing-hicas/
  • Replies 52
predator666,
If you go to the Whiteline website they have some info on HICAS bypass kits, and I believe are coming out with one of there own. For track use disabling the HICAS is a good idea, but for daily driving I would probably keep it. The bypass kits have tended to be quite expensive, so what you have done is a much cheaper option, but leaves you with the HICAS light on the dash.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8292-removing-hicas/#findComment-119857
I'll remove the steering wheel and disconnect it in there - going on a previous post that is the best place to do it. Guess if starts acting too funny I'll connect it back up.
GTS-t VSPEC: true in some ways, but I just don't like the way it handles and it seems its fighting my ass end if if I'm doing corners sometimes the way I do (not all the time!). And in the wet well i'm a bit worried how it will react if i lose traction and it goes sideways. In my old car i knew precisely how to control it when that happened at it was me controlling that back end... in fact i used to do it a bit just for kicks to scare those behind me :D
I want do the bushes fairly soon to give increased traction as well or possibly set it up to try some drifting..not sure, will see.
https://www.sau.com.au/forums/topic/8292-removing-hicas/#findComment-119913
Nissan Skyline R32 GTS-T, KYB Buzz Spec Shockers (Damper Adjustable)
huh? That is the 2nd one on the page?
I already have adjustable zeal coilovers for the springs - dampner and height adjustable. That should do for now in terms of that side of things.
btw: Its an R33 - sorry for not posting that b4.
https://www.sau.com.au/forums/topic/8292-removing-hicas/#findComment-120055
Thought it might be that one. The R32 one is apparently hyraulic and the R33 is electronic.
Therefore with the R33 it should just be a matter of disabling the electronics. When i think about it though, unless it is actually locked it still might be a bit floaty.
https://www.sau.com.au/forums/topic/8292-removing-hicas/#findComment-120091
Check out this link
http://homepages.tig.com.au/~robs/hicaslock.htm
Like you said, for the R33's it's a bit more complicated cause you have to fool the computer and lock the rack.
If you don't lock the rack, you end up with lots of toe in and when turning hard corners the wheels can actually push the fluid around !!!
I've got a Tomei HICAS lock in mine :( but I haven't driven any other R33's so I can't compare.
J
https://www.sau.com.au/forums/topic/8292-removing-hicas/#findComment-120196
BTW the hicas is only active at speeds above approx 70-80kph, and even then only moves the wheels a max of 1 degree.
I have heard this, but its mainly taking a corner and trying to kick the ass out. It just "feels" funny when i'm doing it - like the ass end is all wobbly. Of course if the wheels are spinning too much wouldn't it think it was going 70-80km/hr and kick in the HICAS?? It could just be a need for stiffer bushes and stuff which i'll get fitted soon
See that is the thing - I don't really know what its doing and would prefer it just to handle like any other RWD which i've driven for years.
https://www.sau.com.au/forums/topic/8292-removing-hicas/#findComment-120201
Originally posted by GTS-t VSPEC
Jay,
Thanks for the link, it sounds like the only real way to do it. I'll have to get the kit when I take it out on the circuit. Is it widly available in Aus?
See'ya :burnout:
No problems :(
I'm pretty sure it's available through UAS or JMS, or they can order it for you. Actually, it might be even cheaper though http://www.takakaira.com/
I was lucky cause my car had it in already when I bought it.
It was funny cause I only found out that it had it about 9 months after I bought it !!!!
J
https://www.sau.com.au/forums/topic/8292-removing-hicas/#findComment-120228
Originally posted by CanberraR33
Is it true that if you replace the standard steering wheel on an R33 that then HICAS will be disabled?
When does HICAS activate? Is it constant or only above a certain speed?
I haven't had any experience with the Skyline, however the HICAS on the Zeds is pretty much the same.
The steering angle sensor is mounted in the steering column, so if you change the wheel it may not work properly, will most likely cause a fault code and then the HICAS will disable, similar thing will happen if the steering wheel is not fitted straight.
HICAS is active above approx. 60kph and takes inputs from speed, steering angle, throttle position etc. It's constantly moving the rear wheels to keep the car balanced.
I have some really good info on the HICAS which I can scan and post if anyones interested, explains it fully
https://www.sau.com.au/forums/topic/8292-removing-hicas/#findComment-122634
all you need to do is unplug the motor to the hicas to eliminate it
crawl under the rear of your car and you will se the motor near the diff
unplug the wires(hicaslight comes on ) and hicas is disabled
you may think that it will move freely now,,,wrong the motor wont move at all its locked into position internaly untill its told to move
the lockout kits are expensive because they have a curcuit to fool the hicas computer into thinking its still working so you dont get the hicas light coming on thats all
https://www.sau.com.au/forums/topic/8292-removing-hicas/#findComment-122678
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
