Hi Everyone,
Does anyone have any info/suggestions with regards to the standard intake plenum I have on my R33 GTS-T with the piping running over the motor to the throttle body.
Which of the following options would be best?
1) Aftermarket plenum (e.g. Greddy). I know that I can get one delivered for just over $1000
2) GTR plenum...is this possible? if so what other parts would need changing to make it fit? What would the cost be?
3) Have the throttle body location moved on the standard plenum? Is this possible? What would the cost be?
...or is the standard plenum fine as is running the piping over the engine from the front mount and spend the money on something else? I am looking at getting power up to 300rwkw, and thought that the heat caused by running the piping over the motor would not be as good as having the piping running straight up to the throttle body like the GTR.
Any info/help would be greatly appreciated. Thanks
https://www.sau.com.au/forums/topic/82940-intake-plenum-question/
Did you try searching the forum?
I think sydneykid mentioned the stock plenum was good to a specific power figure but I can't recall the figure.
Ed, after a bit of searching with different search criteria, I came across the thread you were mentioning. Sydney kid mentions the standard plenum can cope with up to 450hp without restriction...not sure if this is crank or atw.
So I can definitely forget the aftermarket plenum and stick with standard. :D spend the money on other things for the car instead.
What about the piping? Will the piping to the standard throttle body position get in the way of a high mount GT35R?
The 180 degree bend at the throttle body style of pipework is the go.
I have a picture of a car fitted with the 180 degree pipework and a high mount, but this new forum is taking some time to get used to.
:D cheers :P
Hey SK, thanks for the pic...looks like it should shorten the pipe a fair bit and looks good to. Was that custom piping made by anyone in particular?
Thanks,
JB
side note, you dont need a GT35 to make 300.. its overkill.  :)
I was also looking at a GT30R with a .82 A/R...may still go for this instead of the 35R. ;) cant wait to start working on it all but will have to wait another year. Then I will give it some attention. :)
Just letting you know thats a Hypertune/Performance manufacturing piping kit.
They have moved from inside the same building as where plazmaman is, but they are now down at Tarin Point.
They will also be doing a plenum for the RB25 very shortly wich replaces the inlet runners.
These are the guys that did all our piping on our GTR.
Give then a call
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
