I catch my front torque gauge working only sometime, whats up with that. Does anyone elses actually work properly, or is that how they work?
I see it jump up and down once every now and then...
Does this measure the torque under acceleration or what?
cheers
Tom
https://www.sau.com.au/forums/topic/82952-r32-gtr-front-torque-gauge/
It measures the amount of torque, as a percentage, that is going to the front wheels. You will often see it jump up and down between 0 and 10 but you aren't having fun until it nears 50. Unfortunately, by the time it nears 50, you are going to have trouble finding the time to watch it.
Torque is fed to the front wheels under 1 of 2 (main) conditions:
1. Acceleration
2. Loss of (rear) wheel traction.
1 - sensors under the centre consol sense longitudinal (acceleration) and lateral (cornering) G-forces, then the ATTESSA computer evaluates and sends appropriate drive to the front wheels.
2- uses the ABS sensors to detect rear-wheel slip.
I get the "jump" often, usually on the highway where 2 lots of bitumen join. I don't know what causes it exactly, but it's probably a loose / dirty / ? connector somewhere in the ATTESSA system.
The reason you don't see it move from 0 much is that the 32 is really rear drive biased. 33 and 34 run more front torque you will see it used more often.
Or buy a torque split controller and dial in more 4wd yourself ;)
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
