I took my car to get the suspenion check out as i had a slight banging sound coming from the rear of my car, pedders told me my car was stuffed would cost 1000k to fix i was like no way.
So i took it to this guy in kippa ring he fixed it all for 200bucks.
overnight job i was very happy with his service seemed like a really honest guy.
anyway the point to this thread is im giving him a free plug
so if anyone needs work done i would say give this guy a call
Scott Darra
Motor Sport Shocks
Ph:0433 227 101
i would also recomend fulcrum
also fulcrum are also the australian distributor of tein as well.
pedders, well lets just say their reputation precedes them. most the people i have spoken to regarding them all have similar things to say about them and none are good.
Ahhh, Scott. He USED to run TSR before it went bad. He sold it, it went bad.
Scott does really know what he is talking about most of the time. I dont agree with a few of his ideas, but hey, handeling is subjective.
twoquik, thanks for the tip!
Motor Sport Shocks sounds like it's worth checking out.
As for Fulcrum, they have a few workshops around town.
for skylines, anyone shop better that others? or person to speak to?
Thanks
PEAR
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
