Looking purchasing injectors for a RB30DET build up very shortly
Ive seen that SARD injectors are "on sale" at most jap online stores that people are pretty familar with here on SAU.
But ive heard mixed bag opinions on SARD products.... but mostly on the Fuel reg and its diafram strength....
Basically ...
Are the injectors alright to use? i shouldnt have any issues?
Anyone using Sard injectors?
Im looking at 800cc as overkill for my RB30DET build up .... would b better off with something smaller 600 mark or something?
my goal is 300rwkw at maximum. planning to run a turbo of GT30R or bigger.
thanks
Matt
https://www.sau.com.au/forums/topic/82978-sard-injectors/
Guest DIRTgarage
Basically ...
thanks
Matt
what you might not be aware of is.....there is no such thing as SARD injectors as such....all the japanese aftermarket injectors are made by nippon denso....so the brand is only refering to the box they come in ...HKS SARD BLITZ NISMO etc are all made by the same manufacturer.....don't listen to silly wives tales as 90% if them are false.
p.s. we use a SARD regulator to control one bosch intank and two external motorsport pumps.....most of the trouble with regulators is using an incorrectly sized return line to the tank or incorrect voltage to the pumps.
https://www.sau.com.au/forums/topic/82978-sard-injectors/#findComment-1502061
im using a RB25de R32 head.....and probably a RB20 silvertop turbo plenum assembly.... hence i wanna use top feed.... rather than using side feed nissan rb25/toyota 2JZ injectors
and ahve u seen the price on nengun now for 740cc's? its a bit more than what i remember u paid for em .. thats for sure.. i think
Matt
https://www.sau.com.au/forums/topic/82978-sard-injectors/#findComment-1504017
blitz injector = siemens.. more injectors are siemens product
Most injectors are nipon denso injectors rebadged.
if you can find a supplier in America and match the injector to your car you can get em delivered for half the price thank the sard/hks etc.
BTW I have sard 550cc injectors with collars and they aint the best. They are direct fit my ass!!! They were a pain in the ass to install and dont give the best economy. If i was to buy injectors again I wouldnt get the sards.
https://www.sau.com.au/forums/topic/82978-sard-injectors/#findComment-1507652
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
