Had a trial run yesterday on the dyno where we are holding our comp on the 27th, I lowered the boost slightly to 12psi from 12.4 and took my car from 168rwkw in 2nd to 174rwkw in 4th, I can't remember how much I got last time in 4th but I think abour 162.
This goes to show that haveing the righ amount of fuel is very important as my previous run was leaning out.
Getting S-AFC and adjustable cam gears next week and will have them installed for the dyno day. Hoping for 190rwkw on 15psi.
https://www.sau.com.au/forums/topic/83-my-latest-dyno-result/
great result Cam found my problem the turbo is shagged I was going to hiflow but you just conviced me to rebuild it. $550 :-) or I might just put a slightly bigger front wheel on. the guy goes just change both wells to biggger yeah I go right and boost will con on a 5k rpm like wd and rudy not for me thanks.
It really it proving to be a good econimiacl turbo even when you consider the price plus a rebuild but JMS have jacked their prices up 400 for the ceramic non ballbearing and the steel wheell like mine is now 495
meggala
https://www.sau.com.au/forums/topic/83-my-latest-dyno-result/#findComment-2194
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
