For sale: 1989 180sx ***
Asking Price: $16,000 ***
Engine Type: Ca18DET to 2.0 ***
Complianced: no
Road Worth Certificate: no
Registration: no
mods
ca18 det to 2L
5 speed manual
Aftermarket Parts:
HKS 2.0 stroker kit (HKS Pistons, rods and crank)
Tomei cams gears (possibly cams as well)
Kei office Coilovers front and Tein HA Rears
Twin layer radiator
ARC front intercooler 108 thick with all new piping
Jap Oil cooler with remote filter kit
Apexi Style Pod
Defi style boost guage, Blitz water temp and oil pressure guage
Oil catch tank
5point half cage
Earthing kit
Push engine starter
Master cylinder stopper
Nordi steering wheel,
Shift knob,
FET turbo timer
GT wing
TD05 kit with Trust 48mm external wastegate
z32 afm
re map e.c.u from jap
Mechanical LSD
injectors 550cc
OS Giken twinplate clutch
fuel pump
3' Exhaust Systems
think thats all the mods
make 194rwkw on 1 bar with a base map
i have had it hear for 2months i have put a lot of new things on the like the cooler/ turbo kit , exhaust and more i have spent about 5k on i since landing
Pics can be found at http://www.nissansilvia.com/forums/index.p...howtopic=104981
Can you provide any documented proof of the stroker kit?
Going off the pictures on ns.com, when you got the car it didnt have the TD05 kit, what turbo was it running exactly?
The car was using a T28 S15 BB, it was an abandond project in Japan so they slapped a T28 on it and just a ARC cross pipe cooler and a safe map and sold it off.
The engine work was performed in Japan unsure of the garage. The previous owner stated he had put a HKS stroker kit in the car and judging by the toqure this car procduces and the way the curve runs, this backs up his claims. Also at MAS this car made 50more dyno nm of torque than a SR making 20kw more
I will post the dyno pic as well.
Also the car is being retuned currently and shold see 215rwkw on 15psi.
Here is the 194rwkw Dyno sheet, this doesnt really show what iam talking about, ill dig up the other sheet for 184rwkw. that backs up my claims.
Dont bet on it.
I recently sold my 180sx, with a similar setup, TD05-16G turbine kit and it made around 180rwkw on the 1.8.
I will have to look and see if I can find my dyno sheet
