hey guys... im a new member to this club... i used to own a soarer and have just sold n imported a Black Skyline R32 GTS-T.
i would like to upgrade the turbo 2 a HKS 2530 or garrot 2530... i have been reading alot about them on this site and it seems to be the best bolt on upgrade!
i would like to know where to buy these from?? or if any1 here is selling them ??
thanks, rhett
https://www.sau.com.au/forums/topic/83031-gt2530-where-can-i-buy-them-from/
that, or go check out www.nengun.com and have a search through there.
IF you want to pay more than they are worth, you can also goto www.hks.com.au and buy them directly off the australia hks distributers, they are a bit of a rip off tho, got quoted $1300 for an hks ebc 4 which i can obtion for roughly $700.
Go to www.nissansilvia.com and go to the sponsors section. Plenty of garretts for sale there.
IMO dont waste your money on the HKS. Get the Garrett GT28RS. Its virtually identical to the HKS 2530. (Compressor is 62 trim on the garrett, 63 on the HKS = bees dick all difference).
www.horsepowerinabox.com
are the GT28RS's are a direct bolt on to the GTR like the 2530's are??
No*. Busky2k probably meant the GT2860 (707160-5).
* ATP Turbos offers a customised GT28RS with the right flange/exhaust housing: http://www.atpturbo.com/
It's a shame that there so expensive and hard to find because I would snap one up at the right price similar to the GT2530
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
    • Being a manual, we very quickly ordered new R34 gearbox (From Nissan) and remaining parts from Kudos motorsports. Would highly recommend the team there. Ultra helpful and quick to share advice and upgrades. We are in the middle of taking the Auto out (Genuine 94,000/kms) and putting the Manual in this weekend. Part 2 of the build will include likely a Plazaman Intercooler and Plenium, Hks Exhaust with Tomei Dump (ordered).
