Hey ppls.
Well, you probably all know about my loss of power after fitting the Tomei Poncams.
Well, here's a question.
My exhaust cam is set at 2 degrees retarded and the tune was done like this.
If I set my exhaust cam back to 0 and reset the base timing, will this make a massive difference to my tune, and will I need to get it back up on the dyno and adjust?
I wouldn't think that I would need to, as I figure the airflow has more to do with it than 2 degrees of cam timing, but I've been wrong before.
All help appreciated.
BASSS OUT
Hey ppls.
BASSS OUT
Do you mean you've fitted tomei poncams? or cam gears? cos they are 2 different things! cam gears change the timing and the poncam cams are the actualy camshafts - I haven't heard many people losing power from fitting larger camshafts, but I have heard many people losing power on cam gears :(
I've fitted Tomei Poncams, and I also have an Adjustable HKS Exhaust Cam wheel.
We fiddled with the cam gear when tuning the cams, at 4 degreed retarded we made same power as 2 degrees retarded, and at 2 degrees advances we made 30rwkw less!
So we played around a bit, but ran out of time to set the exh cam gear to 0 degrees.
Hence, I would like to try this and see how we go, but I don't have a had controller or dyno at my disposaal.
BASS OUT
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
