  • Replies 98
Adrian interesting point you raise about the old school boys... My old man and my uncles and his old boy ( read 50+) friends used to race nearly every weekend at castlereigh, and they all say the same thing when we talk about skylines at bbqs etc "geez there quick for a car you can drive everyday in comfort".... Back in the day my old man was king cause he used to be able to build 202's in hr holdens that ran in 14s... And they used to race a fj with a 427 chev in it that was registered and did low 12's high 11's on street tyres. They all used to travel down to melbourne in it, it was bright purple with "ANY TIME" signwriten down the side in a austin powers type font, and race people for slips, great storys. back to the point that was basically one of the very fastest genuine street cars in australia back in the early seventies and was running low 12's... Now to say you run a 13 or even a 12 doesnt have the impact it should, cause thats still a damn fast street car, plus alot of people dont actually know what a true 12 second car goes like... The amount of young people that I talk to that think they have been in 11 10 second cars then you take them in a 12 second car and they shit there pants and think it runs 9's or something ridiculous. Numbers are too casually thrown around these days without people backing them up!!!!
i believe 10's are the bench mark of a street car these days.
i know my own car was drvien to from newcastle to qld jamboree last year and then drove it home again and it ran an 11.80
all i have done now is put a bigger stall in and bigger injectors and it runs 10.7, it gets driven 400k's a week and the engine has done 187000k's.
Didnt you also run NOS to achieve your 10 sec pass?
What car is it?
Guys how is your MPH measured down the quarter? I asume its the speed you reach crossing the finish line. With a GTECH I manage a 13.3 with 113MPH. That MPH sounds way to high for the times and car I have. I have a R33 GTST with around 200rwkw and standard turbo cheers.
GTEchs times are pretty accurate when set up correctly but its the mph that are not, upto 6mph out.
And I have to agree with the topic, 12's are the norm these days. having been a regular spectator at WSID, unless the car does a huge launch and/or wheelie, or runs 10's, not many people are interested.
With the advancement of technology, particulary in the EFI, electronic and turbo fields, 11 second street cars aren't unccmmon these days with quite a few street cars easily capable of this (and more).
Edited by NXTIME
G Teech is a video game, do not confuse it with a drag strip.
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
    • Well, yeah, obviously. But then you have a turbo with 270kW "design", meaning it will have the higher boost threshold and lag of a bigger turbo, but only doing the work of a smaller turbo. That's the suck. That's actually exactly where I am right now, because my stocker exploded and I got Tao to do a highflow for me. I got a low pressure actuator on it and don't push it past ~10 psi or so, where the stocker was being run at ~12 psi. it makes a little more power than the stocker did, but it lags like a bitch. But, if I run any more boost it starts to ping and the ECU goes into panic mode, which cuts all the fun, so it clearly needs to be tuned. But, until such time as I (which is not I, it's my bro-in-law) can actually get the dyno working again, and get some injectors, and do all the swap over of those and the R35 AFM, I can't attempt to use the turbo the way it really deserves to. So what I have now is something that drives worse than what it did before it filled the cat with little pieces of turbine. I will tune it eventually, and probably only push it up to ~250-270 rwkW, which is pretty close to the max for that highflow anyway. I would imagine that by getting the tune right, and with newer betterrer injectors, we can probably make the boost come on a little earlier than it does now.** And if I do not think that the top end reward is worth the low end sacrifice, I will sell it off and convert to a G30, because the smaller ones of those come on boost very nicely on a 25 and make more power than I realistically need or want. The only reason I didn't do it at the time the turbo blew up is that I wasn't ready to sink a lot of money into an Artec manifold, reverse rotation turbo, the AFM and injector upgrade that would have been immediately compulsory, and the dyno was being problematic.*** It was easier and faster to just put the highflow on. And then, as I mentioned in an earlier post, even that is not "easy", because Tao's highflows use a shorter core than the Hitachi, so the compressor housing moves backwards in the bay, necessitating that all of the pipework had to get modded. ** And maybe just maybe, check the valve clearances and put new shims through, because I have recently seen firsthand on another motor that sloppy clearances on the shims can cost a lot of effective timing and lift and really slow an engine down. 3S-GTE in a Caldina got new shims, closing the clearances from just above the max to right down near the minimum, and it is a massively different car to drive. On boost the better part of 1000 rpm earlier!
    • ooooooh so this is where they get posted  Was at a wedding that day anyway, but the next one I will be there for SURE.
    • @PranK, why do we have this restriction? Because photos are the first thing that gets asked of new people on the forums. Do the spam bots post photos if allowed?
    • How do you rate the clutch @joshuaho96? Sometimes I wonder whether it's genuinely very driveable or whether I just feel that way because it cost a good chunk of money. Most recently when seeing the guy at the tyre shop struggle to move the car...
