I'm happy to say that I cracked a 12 with the Std turbo on my final run at WSID tonight :);) ;)
ET: 12.993 @ 104.40mph (60" 1.777)
After so many 13.1's and 13.0', it was good to finally get there :)
Also ended up winning 3rd in the reaction time competition, so a bloody good night all round :D
hey congrats i saw u running, impressive and i like the stock look!
would you mind listing your mods and what boost you run? i would like to run a 13, (with full street tyres) but need a few things changed so im interested in others to compare..
and btw the black wrx ran a best of 12.6 not 13.0.
apparently there was an accident at a roundabout nearby which stopped people from being able to get into wsid, the lady at the food shop told me, this would explain the lack of people.
Edited by siksII
  • Replies 98
Thanks mate :)
My current mods are:
PowerFC
EBC
FMIC
3" turbo back exhaust
Splitfire Ignition Coils
K&N panel filter
HD clutch
I was running 0.8bar (12psi) boost.
Good luck with the 12 ;)
Thanks mate :P
PowerFC
EBC
FMIC
K&N panel filter
HD clutch
Good luck with the 12 :)
sounds exactly like my car but i also have adjustable cam gear, and sheilded pod(no difference, only good for making annoying noise!)
i will be running with sticky normal tyres 255 wide toyo T1-Rs.
at the moment the car only runs 97-99mph and 14.5(on old tyres with crap 60') so i need to get a retune then i will run it.
anyway, the miss wednesdays all looked like they were 12, or else skanks, apart from the one tall one, im surprised your all interested!!!!!!
Edited by siksII
What's not to like?
Hmmmm, on second thought, im not sure what i was complaining about, your right!!!!!!
btw, i remember u saying you would be back when the weather is colder (ie now) to run a fastER time, have u been recently, hows the car now? larger turbo fitted? :)
The story is in my signature! The one year anniversary of my M Coupe being taken off the road for modifications is next Thursday 25th August. Same night I got booted from WSID after running a ten second pass.
Oh my god, i cant believe that was a year ago, it seems like a few months!!! that was the first time i went to the drags (to watch)
so whats next, 9s?
Yes definently is 12 second passes now the new 13 seconds
My brothers old car a S15 200 and and it ran a 13.2 which seemed really quick 2 years ago and was pretty much invinsible on the street but nowadays is concidered quite timid
As time goes on times will always tumble and i think in about 2-3 years time 12s will be average and 11s and lower might be considered quick
each to their own i say......ill be pushing the limits of our setup before reaching for the gas tap
Thats a fair call, but age and wear and tear is against you. In a stock car i did a similar thing, 2 years later when im ready to lean on it everything i replaced 2 yrs earlier is worn and needs replacing again :D
Make hay while the sun shines, get a few gas passes in, see what times it runs, then go back to running without the gas. Hell see if you can get near the gas time wihtout it by improving the setup, clutch etc...hate to reach the stalemate with your current setup driving for 6 months for 0.1sec only to kill the thing with the first hit of gas :(
Still think all you boys should just throw these engines fof yours into tubbed LJs with auto boxes :D
Edited by Roy
Thats a fair call, but age and wear and tear is against you. In a stock car i did a similar thing, 2 years later when im ready to lean on it everything i replaced 2 yrs earlier is worn and needs replacing again :(
Make hay while the sun shines, get a few  gas passes in, see what times it runs, then go back to running without the gas.  Hell see if you can get near the gas time wihtout it by improving the setup, clutch etc...hate to reach the stalemate with your current setup driving for 6 months for 0.1sec only to kill the thing with the first hit of gas :P
basically i put mine on gas as my 1/4 mile times were not upto scratch due to having a small capacity engine not being able to drag the stall up to its needed rpm. i had a 3400 stall and the when te engine was cold and the box was cold it would stall up no problems. when it was warm or hot after a few runs it would stall up resulting in low 12's at 124 mph and 2.2 sixty foots. the 40 shot gives it enough extra hp to get it on stall and give me consistant sixty foot 1.5's which in a 3460 pound rwd car is pretty awesome on street radials.
i would like to see some 10 sec GTR's run these type of sixty foots in RWD mode,
i never wanted to put mine on gas, but it was the only way to drop my sixty foots and get the car consistant. dont know what others think but i teckon tens out of a stock internal and stock head 2.5 ltire engine thats done 189540k's is pretty damn good.
would love to see what she will do with a plenum, throttle body, head work bug cams and some internals for longevity.
shane :)
Edited by 1JZ.747
shane  ;)
Shane,
Good effort and nice _Zoom_ feature. The world is full of weak c**ts who will never (or can never) give credit where it is due. Just go by the opinion of those you know and respect.
Shane,
thats precisely what i do Mr Blonde, and thanks for the positive comments.
i take it you have a zoom subscription, i have too wait for it to come out at the newsagent. sucks.
well in relation to this topic for me the bench mark for a quick-ish street car was being able to do a 13 and run at over 100mph. now it's definately being able to go a 12 and run at over 105mph. maybe even 110mph. so for me 12s are the new 13s no doubt.
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
