I need to upgrade the wiring to my fuel pump so I can run the standard gtr pump @ close to 14v
Does anyone have any detailed pictures of how to do it?
I understand i need to put in new wiring + relay and fuse and have this connected direct to the fuel pump
Does this mean i need to physically remove the fuel pump and connect the new wiring direct to the pump itself, and put a hole through the grommet and all the other stuff ? Do i need to cut one of the wires leading into the nissan typical 5 plug and connect it to the relay
I would really appreciate any help, because i need to get this done by tuesday
Cheers
https://www.sau.com.au/forums/topic/83118-fuel-pump-relay/
Guest two.06l
Cheers
Tommyk....ring me and ill step you through it mate....02 49847847
Paul
DIRTgarage
https://www.sau.com.au/forums/topic/83118-fuel-pump-relay/#findComment-1504292
Measure the voltage at the fuel pump before you bother.
The OEM fuel pump relay is in the boot near the battery. There is less than 1m cable between the fuel pump and the battery.
The voltage drop over that length should be negligible...I'll explain why.
Assume the OEM cable has a cross sectional area of 1mm squared (it's actually much thicker)
Assume 1m cable
Assume resistivity of copper is 0.0000000168nΩm at room temp
Now, resistance of the 1m cable = resistivity x length / area
= 0.0000000168nΩm x 1m / (1/1000000)m
= 0.0168Ω
Now, voltage drop is given by current x resistance
Assume the fuel pump draws 10A (should be a bit less)
Voltage drop = 10 x 0.0168 = 0.168V
Which is next to nothing
Soemone please correct me if I'm made any errors
https://www.sau.com.au/forums/topic/83118-fuel-pump-relay/#findComment-1506869
Thats correct Mik, however the high low resistor is what causes the fuel pump not to receive the full volts when under load.
Unsure why that is my understanding.
Running a dedicated power feed does indeed help.
I'll be grabbing the multimeter and checking mine out. I run an external and internal pump, both of those running flat stick must be drawing quite a few amps, hence my reason to upgrade the wiring to a minimum of 30amp stuff.
https://www.sau.com.au/forums/topic/83118-fuel-pump-relay/#findComment-1506874
I have run dedicated 30 amp wiring with a 20 amp fuse for my external pump (044). A relay is triggered off the factory power feed to the intank pump. The intank pump (walbro) is still running off the factory wiring through the stock 10amp fuse with no problems.
I also run a surge tank with the return line feeding back into the top so the 044 is effectively feeding itself once primed if the walbro cant keep up.
Only problem i have is the PFC doesn't prime the pump long enough for the 044 to build up rail pressure so i have to turn the car to reds, then off, then back on before cranking.
https://www.sau.com.au/forums/topic/83118-fuel-pump-relay/#findComment-1506992
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
