Had my RB30DET on the dyno today hoping to up the boost to 15psi. Problem is it started to lean out at 12psi and feeding in more duty cycle to the injectors didn't seem to have any effect on the A/F ratio. I have a Bosch 910 pump which should be good for 450-500bhp, 550cc injectors and am using the standard turbo pressure regulator. My tuner thinks the reg is not holding the pressure high enough on boost.
Is this a fair call?
He has suggested a Malpassi, but i remember hearing that the pressure can fluctuate a little with these. Anyone have FIRST HAND experience with this?
https://www.sau.com.au/forums/topic/83123-rb25-turbo-fuel-reg/
Did anyone check the fuel pressure when this happened? It's pretty easy to spot when the pressure stops rising with boost. If the pressure increases and then hits a wall then it's the pump.
My malpassi allows fuel pressure to fluctuate by about 1 psi eachway.
As nismod has stated it is worthwhile running a dedicated power feed to the pump with a relay triggered off the current pump power feed. It also eliminates the fuel pump speed control.
The 910 may be a bit undersized for your application, an 040 intank pump is pushing it at 260rwkw and the 910 is a bit smaller (i think).
We ran out of time to hook up a pressure guage on the day. What i plan to do today is run some compressed air at 12psi into the reg and measure how much fuel is returned. At the same time i'll check the pressure. This should tell me... a) how much fuel the engine can use without the pressure dropping off and B) if the reg is actually working correctly.
Dump_pipe, I bought a R33 DE head for the conversion and changed the reg for an R33 DET unit. Part numbers are definately different. I guess the DE reg dosn't have the rising rate ability that the DET reg has.
do they make direct swap nismo ones to suit?
Yes they do - mine cost 170aud delivered a year ago, very easy to fit too. I've also been told that melpassi's don't hold good steady pressure - haven't had first hand experience though with the melpassis but with the fuel press guage on the dyno my nismo held rock solid fuel pressure with a bosch 044- no flicker at all. But as everyone seems to say you don't need an adjustable reg unless going crazy on power or want to put more rail pressure.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
