im getting my fc installed and tuned at chasers for 450 and for a retune of fcs the charge 132 for the first hour and 88 for every hour after that? does that seem ok i was going to get a service there but they want 750 for all this
Full service includes - timing belt/seals, engine oil (motul 4100), oil filter, gearbox oil, diff oil, fuel filter, spark plugs, coolant, fluid topup and general inspection. $750
cheers simon
also are chaser any good now they seem to do alot of motecs now not fc's
Edited by gt-t_r34
  • Replies 57
  • 2 years later...
1. COST - $1000
2. Mods you have done - FMIC, Pod Filter, Apexi Turbo, Extractors, 3inch Full Exhaurst, Cams, PFC
3. Where u did it - Gentech, Canberra
4. How long it took - 2 Days, Full Tune from blank and cold start.
5. Comments - Very happy with the end result and the after service help.
It sounds a bit expensive then what every one else has said but they did tune the car all day as he was ringing me as he did it. so for all the time and the end result i think it was worth it.
Adam
  • 9 months later...
  • 3 weeks later...
  • 2 months later...
  Keeper said:
Cheap tunes arent always good tunes, my last tune cost me about $8k in a rebuild so-far
yea your rite, for an extra few hundred its worth goin sumwer wer they will do a decent job, atelast you will save yourself the $$$ thousands in the long run if it blows up
i pay 900 at racepace nd can say confidently its worth every dollar...
price: 900
mods: fully rebuilt rb26, cams, turbos, fmic, etc, etc...
Just got mine fitted and tuned at Autotech recently.
Paid around 700+ for the tuning alone (my first tune)
Very happy with the results but not perfect as somehow something is making the boost controller not holding boost.
mmm....I was just thinking the other day how you would have gone with Gavin....so they had it for 3 hours i'm guessing.
1. COST - $700 for full first time tune
2. Mods you have done - FMIC, Apexi Pod Filter, GT3071R, Exhaust, Profec B, Spitfire Coilpacks, 550cc Injectors, Walbro Pump, z32 AFM
3. Where u did it - Unigroup Engineering in Sydney
4. How long it took - Gave it in about 5 days ago to put the turbo, injectors, fuel pump, AFM and PFC. Should be done in 10 days total
5. Comments - I've heard good things about unigroup and the initial meeting went very well. They have kept me informed of the progress. Will update when I have the car back.
Edited by usmair
Yea 3+ hours on a 4wd dyno. Made 255awkw @ 1.1-1.15bar boost, 165awkw @ 0.6bar before. Not looking at the figures, the car shit loads faster and smoother. Complete joy to drive now comparing to before.
  • 1 month later...
thanx now i got a price to work with!!
  Cubes said:
Charged: $100
Mods: FMIC, 3" Turbo Back Exhaust, PFC, RB30DET.
Tuned By: Shaun @ Boostworx in Adelaide, SA
Time Taken: 1hr (I Hung Around)
Comments: Very happy, The 3ltr only 'just' ran on the stock RB20DET 2ltr PFC base map. Very good tune for bugger all bills.
The tune was 90% wot tuning with a few little light load adjustments.
It made 176rwkw with the stock RB20DET turbo running 9psi @ 4400rpm-4950rpm, power drops off rapidly after this rpm.
I've reached the limit of the stock rb20 turbo and injectors as they are hitting 100%.
I will be installing injectors and a larger turbo soon, I've been told the tune will cost $200-$300 as he will have to completely go over the light load map. This is what takes time, not the WOT.
1. COST - $300 for full tune
2. Mods you have done - FMIC, Apexi Pod Filter, HKS GT-RS, Exhaust, E-Boost Street, Spitfire Coilpacks, 550cc Injectors, GTR Pump, Z32 AFM, Tomie poncams, CP Pistons, Jun Style Front facing plenum with 80mm TB.
3. Where u did it - SouthCoast Rotary Performance (in Woollongong, NSW)
4. How long it took - About 4 hours
5. Comments - Excellent tune for the money, being a rotary tuner he knows how to set a good ignition map before taking the fuel out. Engine makes good power, with zero knock. Also spent some time on light load, to improve economy.
  • 3 months later...
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
