Make them aware of the problem and advise them they drive at there own risk n get them to sign job card.
Thens its there problem soon as its out the shop , then when shit like this happens they have no recourse on you ..
  • Replies 87
steve you got a pm from my mate anthony. he is a compliancing engineer full time and does it off the side....
he would have sent you one cos u said you are doin it soon.
he has done quite a few cars dude. majority of the antilag cars were complianced by anthony. im sure he will come highly recomended if you asked some one haha.
cheers
Adam
1 - i have no intention of buying or compliancing any 15 plus car since the rule has now ended, buy can you pleeeeeeeeeeeease pm since i have absolutely no need to know except to be a gossip monger - so yeah pm me asap i need to know for .. something
2 - anthony is a champ - did my car, has done alot of antilag cars - professional about it and is in to cars too, so isnt doing it just for a buck ;)
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
