Since my web site is no longer on the www I thought I'd share some interesting and exciting news about rb20det tuning. My mates S13 with RB20DET has just recorded 257rwkw on a DDDyno. This is the same dyno that we have always used and the tuner is the same only thing is that this time is was really hot and the final run was done after a full days tune.
Main (Important Mods)
RB20DET (totally stock internals)
T3/T4 hybrid turbo
ARE front mount
Microtech MT12
HKS cam gears
Pump fuel
18psi
4" dump and 3.5" system
Oil catch can
HKS filter
GTR injectors
Bosch 910 fuel pump
OS twin plate
So there is plenty of power available from the ol RB20 so long as you get 1 thing right......Find a good tuner that actually knows what he/she is doing and is more than happy to talk to you, tell you whats happening, lets you spend the day with him to learn whats going on and even lend a hand.
https://www.sau.com.au/forums/topic/8317-250rwkw-rb20det-how-2/
  • Replies 109
Sure, the guys name is Tim and he works for Cramer Dyno & Performance in Toowoomba. The business started out as a Diesel workshop but now most of their business is performance orientated. They supply and install MOTEC, Unichip and so on but the main thing with them is that they are eager to learn and don't charge for time spent "Figuring it out" as they see it as a learning time for them selves.
For those readers of ZOOM you may remember the Yellow 240Z from the cover some time back well that guy lives in Sydney and he had Tim do all the tuning. Their workshop is immaculate and all the staff are well trained.
Their contact details are PH 07 46 989350 if you contact them tell them you spoke to Cam on the Skylines Australia Forum and they will look after you :(
Saying "T3/T4 Turbo" is about as useful as saying "big cams" :thumbsup:
There is no such thing as a standard T3/T4 Turbo, like there is a standard HKS GT2835R. A T3/T4 is a term made up to describe a turbo with a "T3 sized exhaust housing and a T4 sized compressor housing"... It is something the turbocharger specialist/builder such as XTR, GCG (just two examples), etc puts together for the customer's needs.
One T3/T4 will differ from the next one in terms of compressor and exhaust wheel trims, compressor and exhaust A/R ratios, and what kind of bearings are in the center pack.
rb25 will do it so much easier then a rb20
with a full exhaust, piggy back system & 10psi they are doin 160rwkw on a dyno
How did your mate fit the gtr injectors, did he get a resistor pack off a gtr or get a link ecu with the resistor pack?
the ohm that the rb20 produce are to high for the gtr injectors.
T3/T4 is a loose term used, its getting the best of both worlds from the 2 turbo, its a hybrid turbo.
the T4 compressor wheel & the exhaust housing from a T3 to reduce the lag from a very big t04 exhaust housing eg .90
Guest Works Auto
What a crock of crap. Every rb25 ive seen do more than 300 at the wheels has cracked a ring land or something like that.
There just not suited to high boost . There like a NA motor with a turbo on them.
fair enough, i dont own or know any people with r33 over 250rwkw so i cant say nothing there, but they do tend to ping pretty easy.
Most of the fast r33 that you read on the mag are rb25 head rb30 bottom end.
Why i said the rb25det gets a bigger power figure is because they have 500cc more then we rb20det owners, & can produce 160-170rwkw so easy with just a few mods.
Once you reach above 250rwkw, people tend to break things regradless or rb20 or rb25, engineers never design the engine internals to produce that amount of power.
Im a fan of the whole "RB" engine
I take it you haven't seen many 300+rwhp RB25DET's then!
I've seen/witnessed/heard of many internally stock RB25DET's that produce a reliable 300+rwhp, mine included. There are a few internally stock RB25DET's in the 400rwhp region that haven't cracked rings or pistons & are still going strong. The red JMS GTS25t is one I've watched run 290-300rwkw quite a few times, & it certainly would cop a hiding!
A 200rwhp RB25DET will crack a ring land if it's poorly tuned, or any of the support systems fail (f/pump etc..)
Both the RB20 & RB25 DET engines have great potential, but you can't overlook the extra 500cc capacity for driveability. It'll bring a bigger turbo on boost sooner, better off-boost response & so on. That's not to say the RB20DET doesn't have advantages over its newer/larger brother. Lower compression being the main one.
While talking CR's it's interesting to note the CR chosen by many of the Japanese tuners (& now a few Aussies) CR's in the region of 9.0:1 & over are not uncommon @ all! It all comes down to the tuning & fuel used.
John (Munro) on these forums has an RB26DETT (OS Giken RB30 kitted) with 9.1:1 CR This CR & extra capacity has his 2835R's spooled & providing solid boost by 4k.
Every single word in this post is complete and utter rubbish.
That's right. EVERY. SINGLE. WORD. :thumbsup:
Merli,I agree with you, I think some people take things to extremes.
Works Auto,
There are issues with all engines, few of them insurmountable, and to say sweeping statements like that leaves you open to the ridicule you will get.
There are a number of RB25 engines producing high horsepower, and while many will go for forged internals that is something most engines will need sooner or later. I know plenty of RB26's that have dropped pistons etc.
To get 250rwkw from an RB20 is a very good effort, testament to the RB family of very tough engines.
See'ya :burnout:
Sorry folks I didn't mean to cause a stir by not supplying the specs. So here you go, I trust this is sufficient for you Merli.
COMPRESSOR SIDE:
Cover - To4B with 3" Inlet 0.6 AR
Wheel - To4B v1 / v2
CENTER:
RX7 Hitachi
TURBINE SIDE:
Housing - Safari FORD pickup 0.64 AR (T3)
Wheel - RX7 HITACHI with Cropped fins
Gate - Internal 4mm oversized
We came up with the specs and components for this several years ago and since then JMS have used a similar design GCG also use a very close design but our Turbine housing is much bigger. Here is a pick of the stock RB20det turbo next to ours.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
