Personlly I would suggest finding a turbo specialist and discuss with them what your requirements, in terms of performance, are. They should be able to custom make a turbo to any specs you want.
There are alot of bad t3/t4 turbo's , so do some shopping around.
See'ya:burnout:
  • Replies 109
To be honest most of the rb20 housings (EXH) will be cracked, all the ones I have seen have been so sourcing another one is better. The turbo for Lukes car cost around the $1800 mark but we did source a number of parts and this did include a new oil feed and machined manifold
  • 1 month later...
Hi snOOp, our RB25DET gets 260 rwkw, it has....
GCG hi flowed RB25DET turbo (at 1.3 bar)
Tomei cams 256 degrees (inlet works with VVT)
Jun adjustable exhaust pulley
Cat back HKS exhaust
Split pulse dump
HKS intercooler and pipework
Power FC
Z32 AFM
Jamex panel filter in standard box
Custom fabricated aluminium inlet from AFM to turbo
Did 12.5 for 1/4 at Willowbank just before Xmas in a full weight, manual R34 GTt.
Hope that helps
Hi guys, I am surprised by the lack of use of simple mathematics sometimes, particularly when talking about turbo spool up.
It is pretty simple really, say we pick 3 common RB engines with the same turbo and assume the same engine efficiency. The capacity is the main thing that determines the rpm at which the engine develops boost. The following table assumes the same compression ratio and efficiency in all 3 engines.........
Engine CC's Boost RPM
RB20DET 1,998 3,600
RB25DET 2,476 2,900
RB30DET 2,964 1,950
Simply put, an RB25DET is 24% bigger in capacity than a RB20DET. Therefore it will produce the same amount of exhaust, spin the turbo and develop boost 24% lower in the rev range. Ditto an RB30DET is 48% bigger in capacity than a RB20DET. Therefore it will develop boost 48% lower in the rev range.
If you want to allow for compression ratio, a good rule of thumb is to simply factor in the difference in compression ratio eg; if in the above example the RB20DET had a 8.5 to 1 compression ratio and the RB25DET had a 9.0 to 1 compression ratio, the RB25DET would have boost at 2,750 rpm (instead of 2,900 rpm).
This is not perfect, but it is a good rule of thumb and in the real world is pretty close to the mark.
Another rule of thumb we use is a performance engine should not develop boost until at least 1/3 of the available RPM is used. Otherwise the turbo is too small.
So if we assume that our 3 X RB engines above all rev to 7,500 rpm, then 1/3 is 2,500 rpm. So the turbo would be too small if used on the RB30DET as it develops boost at 1,950 rpm. It could be said that the turbo is too big for an RB20DET as it develops boost at 3,600 rpm (a long way from 2,500 rpm). At 2,900 rpm (or 2,750 rpm with 9.0 to 1 compression ratio), the RB25DET would seem to be a pretty good fit for this turbo.
Hope that makes sense
  • 2 months later...
cam great results as always aren't you getting the turbo bug again :(
good to see you back one the forums great result for for the set up I'm considering a simialr one for my cefiro I have injectors and z32 afm so we will see.
btw all you people saying rb 20 are tough I have popped 2 in the last 18 months cant be thart tough bu tstill a good motor :)
cheers
meggala
Having said that the RB20 is a strong engine, the SR20 is also just as strong if not stronger. Has anyone read of that white JUN s15 tuned here in Australia that has put out a stupid 600 or more horsepower at the wheels!?? Of course it runs a 2.2L stroker kit with TRUST T88...but still, that thing will go :rolleyes:
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
