post-729-1123385028.jpgpost-729-1123385059.jpgpost-729-1123385087.jpgpost-729-1123385138.jpgYamaha R6 2004 Limited Edition Flamed
Hardly riden
Has 3600kms
Has Fender eliminator
Has Carbon tank cover
Has New Dunlop D208 tyre (very sticky)
Will have 12 months rego
Light sctraches on left hand side where the fairing and case cover is (see photos)
Here are the specs:
Engine and transmission
Displacement: 600.00 ccm (36.61 cubic inches)
Engine type: In-line four
Stroke: 4
Power: 123.00 HP (89.8 kW)) @ 13000 RPM
Torque: 68.50 Nm (7.0 kgf-m or 50.5 ft.lbs) @ 12000 RPM
Compression: 12.4:1
Bore x stroke: 65.5 x 44.5 mm (2.6 x 1.8 inches)
Fuel system: Injection
Valves per cylinder: 4
Fuel control: DOHC
Cooling system: Liquid
Transmission type
final drive: Chain
More details Consult a Yamaha repair manual.
Physical measures
Dry weight: 162.0 kg (357.1 pounds)
Seat height: 820 mm (32.3 inches) If adjustable, lowest setting.
Overall height: 1,090 mm (42.9 inches)
Overall length: 2,025 mm (79.7 inches)
Overall width: 690 mm (27.2 inches)
Ground clearance: 135 mm (5.3 inches)
Wheelbase: 1,380 mm (54.3 inches)
Chassis and dimensions
Front suspension: Telescopic fork
Front suspension travel: 120 mm (4.7 inches)
Rear suspension: Swingarm (Link suspension)
Rear suspension travel: 130 mm (5.1 inches)
Front tyre dimensions: 120/60-ZR17
Rear tyre dimensions: 180/55-ZR17
Front brakes: Double disc
Front brakes diameter: 298 mm (11.7 inches)
Rear brakes: Single disc
Rear brakes diameter: 220 mm (8.7 inches)
Price is $12,500
you can email at [email protected]
or
call me on 0402 950 885
