34 GTR wheels with 2 new tyres and 2 ok tyres good nic...$2700
34 GTR Navigation system (non MFD just a cd player that outputs onto the mfd) and standard 34 stacker and 34 a/c head unit..I'll separate but you'd be better off buying it all as it fits with each other...$600 or make an offer.Looks cool together
32 GTR Bilstein suspension in good nic and very low...$800
320k Nismo 34 GTR speedo...$700
51CKR qld plates....$600 or make an offer
40RCN qld plates...$1000 or make an offer
GTR44 qld plates...$650 or make an offer
32 GTR taillights...$200
32 GTR headlights...$200
[email protected] for pics and offers
Ps. I am chasing 32 and 33 GTR height adjustables if you want to do a deal.
https://www.sau.com.au/forums/topic/83203-garage-salegtr-and-other-stuff/
I'm not a suspension guru so I couldn't tell you the spring rates but they are pretty firm and pretty low...hows that for technical.
can you give me some specs on the suspension please?
Silver letters on blue background...I am in Yeppoon qld.
I'm sure it wouldn't cost much to post em..
suppose I'd even cover that cost
hi mate, my name is james, from brissy, where bouts you, jus in regard to personalised plates 40CIN. what colour are they, and what design, like are they jus plain or do they have back ground,
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
