so i lost my licence for 12 months
i got 12 months to do work to the car
i want to get around 350rwkw if thats possible
what mods will i need to do ? and in what order? anyone know
at the moment i have
r33 series 2 gts-t
front mount intercooler
airpod
hks bov
hks 3" exhaust
custom dump/screamer pipe
3" front pipe
cat has been 'damaged'
whats the next list of mods in what order? any help greatly apreciated
thanks
Anything is possible :), just depends on how deep your wallet is.
I can start you off with a pointers though, but it really depends on your budget. At 350rwkw you'd need to get the internals done as well, as thats really pushing the standard internals.
- Full ECU (powerfc?)
- Larger injectors (550cc might be ok, unsure)
- new AFM (Z32?)
- Larger fuel pump (bosch 044?)
- Larger turbo (GT30 or GT35?)
- Boost controller (any of those jap ones are good :)
- Larger cams (tomei poncams 256/264?)
That would probably get you in the right direction, but then you have your internals as well, like pistons, rods,abit of head work etc.
With that type of power you should also get a matching suspension (whiteline handling kit would do u wonders) and brake (brembo calipers with some dba slotted rotors?) setup to help you control your newly gained power.
You lost your license for 12 months and you want to increase the power of your car by 200kws ?
it shows loosing ure licence doesnt teach ppl a lesson
heh
yeah, but ill be keeping it to the track next time and to the drag strip ive learnt my lesson.
- new AFM (Z32?)
Would he still need a Z32 AFM with a power FC?
shit yeah, youll max out the stock airflow meter at 250rwkw
unless you mean that by saying do you still need an airflow meter?
then if he got the d-jetro then you dont need an airflow meter but then the car is a bitch to tune and will run less superiror than the airflow meter setup
Q45 and a GT35R with a .82 turbine housing.
Set of cams.
Spend the rest of the money on a set of Toyo RA1's, RE55s - S for super soft compound. :D
Possibly even a better option again. Nitto drag spec.
What did you loose your license for?
12months, it must of been something drastic.
If it was for speeding or being stupid on the roads consider spending a little on a driving course so you can see how dangerous and uncontrolled a car can be.
when you've got cars pumping out 400-450rwkrw on pulp wuithout much effort at all...
350rwkw is hardly a need for race fuel
And you certainly dont need 2 GT30's to do it. Have you ever made 350rwkw?
And yes... my motor is for sale. Depending on what you want etc. Might save you a lot of time hassle and money
hey on a totally offtopic and unrelated reply, the link in your sig to your for sale thread is b0rked R31Nismoid ^_^
But someone had to use straight 104 octane to get that power reading!!! :lol:
To the guy that started this thread, if you already lost your license for 12 months, and now want 350rwkw, hopefully you have saved money for a head stone also????
leigh i say get as much power as u can all u need to remember is where and when u use it ive being in the same boat as leigh all i can say is f*** yea pump out the figures only young once!!!!!!!!
so?
simply replace with a GT35 and bobs ur uncle. they are the same dimensions so its direct swap.
Although 350rwkw and traction are two things that dont work together one little bit no matter what you do :O
Lets no get onto your car :D
    • Interesting.  Great info. thank you.  Give a few days to get that name plate.  I have a busy life most weeks.  I will be in touch.
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
