Do any of the boost controllers allow you to set boost levels depending on RPM?
For example - supposing I want to limit boost to 1.2bar at 5000rpm and slowly ramp boost up to my maximum boost of (for arguments sake) 2bar at 8000rpm?
The reason I ask the question is that since boost is "resistance to airflow", as you go up the RPM range, the valves are only opening for much shorter periods, and so while you are reading say 1 bar at 6000rpm, you're probably only getting half the amount of air in as you are at 3000rpm when also running 1bar... ( is that theory right?)
So I was thinking that an engine under load 4000-5000rpm might not like 2bar being belted into it, (a bit like a shot of nitrous too early in the revs) but could well handle it up around 7000-8000 rpm?
If a boost controller is set at 1.5bar to "suit" the 4000-5000 rpm range, then am I getting less and less air into it at higher revs as the valves are opening and shutting faster and faster and hence building up back pressure? (ie reading same boost, but getting less air-flow?)
Thoughts?
https://www.sau.com.au/forums/topic/83235-increasing-boost-with-revs-airflow/
ACV-R can do that in intervals of 500rpm
Ah - so it does! (just looked it up)
I have a basic HKS boost controller which doesn't - and I only ever see people quoting max boost.... so I wondered if this sort of thing was played with much..
Sorry if it was a dumb question! I come from a normally aspirated backgorund and am still learning. :)
So would this be the norm then?
Are people out there tending to raise the boost as RPM goes up?
cheers,
An engine at 6000 rpm is eating twice as much air as it is at 3000 rpm. That has nothing to do with boost.
Some people, myself included, use the rpm based boost control of the AVC-R to smooth the ramp up of boost to control wheelspin in 1st gear.
You don't have to do it that way - the AVC-R has a gear learning facility and you can use that to limit boost differently per gear. That way, you can have your full balls out mode in the higher gears while limiting it in 1st to stop wheelspin.
I think it works out what gear your in by looking at rpm vs road speed.
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
