Just picked up my car from Racepace on Staurday with the addition on a HKS 2535... Its an R33 GTST S1.5.
I have to say i am wrapped with how the car has turned out it goes so much harder than it used to and the power delivery is smoother than ever!
Big thanks to Ben and i recommend anyone else to send their car to him!
If anyone is looking for a turbo upgrade, the 2535 is amazing! Not much more lag but it just pulls and pulls the harder you push it the harder it goes! The power is so smooth that traction is not a problem at all....... first gear is a little useless above 4500rpm but second gear is great and that is with the crap Falken 326 265/35/18...
The best thing about the car is that it looks stock standard! You cant even see the turbo under the heat shield...
Big thanks to Ben and ill be back very soon for more work!
https://www.sau.com.au/forums/topic/83237-hks-2535-installed/
PFC
Trust FMIC
Turbo Back Exhaust
12psi
Nismo Fuel Pump
211rwkw....
I am getting an new catback exhaust so i can run more boost and was told to expect in the range of 240 - 250 rwkw...
I am more than happy as it is now but the extra 30 odd kw will be great!
Ben said it drives a lot better than the dyno shows... for now i am very happy with it!
I guess that would have been mine!
I forgot to mention, Nismo Fuel Pump as well but still running the stock injectors and AFM...
I was more than happy to upgrade the Injectors but Ben told me not to bother... They only start maxing out at redline, which my car never really sees...
I have been getting used to the way the car drives so to be honest I havent noticed when it hits 12psi and it wasnt on the dyno readout so ill have to take her for another spin an let you know..
Standard manifold, just looks like a 100% factory engine bay...
After a goo thrashing over the weekend, i can tell you it loves to drink if you push it and the power delivery is so smooth that sometimes it really doesnt feel like it is going hard till you realise who fast you are going...
I have been searching high and low for a good cat back system but have found it is very limited... anyone got any suggestions? I have tried hypertech but thats it so far... and i wasnt that keen on spending another $1200 on a catback..
I have a Blitz Spec R at the moment whcih will be for sale if anyone is interested....
Let me also say that unless your car is standard, the Falken 326's are useless!!
211 kw is not so bad but why not more?
I got 208 on Rajabs low reading dyno at 12 psi thats with a stock CAT and a stock dump pipe and a Unknown remapped ecu.
I know a guy that has a SII R33 GT2535 with 236 rwkw and a tuned PFC. He ran it at the drags with mickey thompson slicks and got 12.7 but was getting 109-110 mph. Mine was getting 111 mph at lower boost, minus computer and exhaust sections.
Is it worth paying all the $$$ for the HKS turbo? I certainly USED To think so, ive had a GT2530 on a SR20DET before, but now Im beginning to question if the outlay of money for these ballbearing turbos is worth it.
Not picking at anything, but its something to think about.
Ben Dyno is LOW reading too. Is it worth getting HKS turbo or local ones? Look at the smile on Silva33 face :).
Don't try to squeeze too much boost because it'll be either your turbo and engine wil go Bang.
I used to have a 33 series 1.5 too, stock turbo, always run 14psi for Three years and nothing ever happened.
hmmmm interesting... im going to be building up something with a 2540, fmic, afm, pfc, bigger injectors, fuel pump and cams so it will be interesting to see how much power i get... as i want it reliable i will only be running lowish boost (12psi - 1bar max) and the power ur getting is about all i want.
It didnt make anymore power with the silencer in the exhaust and without the silencer you can hear me comming from a block away, thats why im looking for a new quiet catback exhaust...
I think the turbo is worth it, when you consider how responsive they are and how smooth the power delivery is i dont think you can go wrong... and the fact that the car still looks standard is a huge bonus...
As far as the motor going 'bang' ill leave that up to ben.. I dont expect anything more than the turbo and motor will safely handle... I am more than happy with the performance at 211rwkw, so anything above that will be a bonus!!!
For normal day to day driving the only other turbo i considered was a VG30 hybrid... I ended up going for the HKS because of the reliability of the results....
so the 2535 is low mount obviously...
does anyone know if the 2540 is a low mount turbo?
lol... narkehh! it can be a 'low mount turbo' if it's mounted on a low-mount manifold you goose. Same goes for a high mount manifold. The manifold determines your turbo mounting position, not the turbo itself! provided you have the space required of course..
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
