lol... narkehh! it can be a 'low mount turbo' if it's mounted on a low-mount manifold you goose. Same goes for a high mount manifold.  The manifold determines your turbo mounting position, not the turbo itself! provided you have the space required of course..
HAHA ok cool... well thats ok then... why does every one opt for a high mount all the time then? i know i would prefer it to be less obvious... then again i guess im more secure in my hetrosexuality and penis size then those opting to show as much off as possible :mellow:
there's a few reasons, one is because the high mount is easier to access and work on than the low mount. It also allows you to display your big shiny fcuk off compressor wheel :blink:
The low-mount is stealth. Good for EPA inspections B)
LOL... yes I suppose Denham doesn't feel as secure as others. :lol:
there's a few reasons, one is because the high mount is easier to access and work on than the low mount. It also allows you to display your big shiny fcuk off compressor wheel :mellow:
i see... so no real performance gains at all?
cheers... oh and again for the number :blink:
haha poor denham... its not all his fault tho... its all about genetics :)
Dumbass u try low mounting my GT30 in my engine bay and tell you how successful u are.
It is also a waste of time high mounting a 2535 or 2540 as they are small and can still use the stock manifold
:mellow: theyre not small... theyre just small next to ur mammoth turbo lol
nark they are small man when comparing to the stock turbo side by side.
I measured the difference in size between the stock turbo and the 2530 and its like 2mm here and a couple there, bugger all really. The wastegate is much bigger though. The inlet neck is also better designed but overall, very little. I wasnt impressed.
Performance wise, the 2530 eats the stocky for breaky. It has so much midrange you can think you can take anyone on. Top end it falls over because its too small. My max power is at 5600rpm, after that you draw a straight horizontal line.
I would love to try something bigger, but i want a bolt on, something i dont have to piss fart around with dumps and inlets etc.
Robo, What about a HKS 2835.... they seem to make decent power...
Once my car is complete with an exhaust i mean, I would me more than happy to compare yours and mine...
At the moment it doesnt really feel like it is dropping of at all, and the dyno reflects that.. i dont know if it becuase i am only running 12psi, which may be the reason.
I had a garrett gt2835 in my hands last saturday at RUS's workshop on sat for an r32 rb20 when they were trying to bolt it on there as owner was told it was a straight fit turbo :P :P
Lets just say it still aint on there and custom mods to exhaust and intercooler piping needs to be made plus the comp and exhaust covers need to be rotated to match the stock turbo positions, and new oil and water lines are needed. It looked a nice size turbo tho
isnt that what kyrz has? that thing aint small at all lol
but the GT2540s are a lot easier to fit right?
Chris is meant to have a hks 2835 pro s which would be modified to fit the oil/water, cooler/exhaust lines for the rb25 fittings.
The garrett ones you need to modify yourself to fit everything. Its still a tight fit on the stock manifold down there for that turbo.
2540 is piece of piss to install
Thats what i like to hear, a bit of competition
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
