I have installed my nismo AFM's, an d now, unfortunately I cannot drive (or start) the car, because the AFM's are a fair bit different compared to the stock afm's
Does anyone know the values I need to enter into the pfc to adjust the afm settings so that i can at least drive it to the workshop ?
Cheers
Tommy
https://www.sau.com.au/forums/topic/83238-nismo-afm-settings-for-power-fc/
I cannot choose that option ?
I have 5 options on the screen, but I cannot individually select one of them. Perhaps I am doing something wrong? How do I choose the vg30 option?
I'm guessing that the reason for this is that is because my tuner has completely locked out my screens. Thats why im very shitty. The only thing I can do, is edit the voltage %'s. But I dont really know what to add
Its a strange way the pfc uses to select the afm you want.
Simply enter the Airflow menu and highlight the one you want using the up/down keys.
Then simply press back to return to the main menu and that afm will be selected.
Just to note though I am able to start and drive my car on any of the afm selections, allthough they don't run it that well but it still runs. :D
Yep..your tuner locked the handcontroller.
I can however edit the %'s next to them
BUT i dont know exactly what to add ?
read what cubes posted again. go in to the AFM option screen. highlight the VG30 option then hit back. you will now have selected that option. Like a said in the first post the car will run and drive but it will need to be tuned as it won't be safe (or any fun) to thrash it.
I dont think so
I mean i can move the cursor over it, and then back out
But when i go to start the car, it starts idles for a bit and then dies
I think i am going to have to install the old afm's
in that case have the AFMs been installed correctly? do the nismo ones use a stock plug or do they need to be wired up like a Z32? this was a problem on a friends car the other day we had. installed Z32, selected VG30 option car idled, then died. turned out it was a wiring problem.
Nismo afm's are bolt ons
I dont think I did anything wrong ?
I just think that the display is locked out and its using the right option.
I am going to reinstall the old afm's and go from there :)
The engine won't run with the NISMO AFMs on the VG30 setting. You need to add a bit of fuel at idle.
ok.
Go in to the airflow menu select option 5 or the very bottom option.
Press back.
Now go back in to the airflow menu and if the option 5 is still highlighted then the menu is definitely not locked out.
It was my understanding if the airflow menu is locked you can't even get in there. :)
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
