Today while leaving, I noticed my car was making a loud whining noise (seems to be coming from the turbo) whenever the engine is revved. I am not exactly a turbo wizz but generally what does this mean? the car still drives OK and I still get boost.
Should i get it looked at by a mechanic or is this something easily fixable?.
R33 GTS-T with stock everything
https://www.sau.com.au/forums/topic/8326-whining-turbo/
Well, It DID get worse with more boost, and once it had idled for a while it muffled out
now it doesnt make the noise at all, and i found the problem. I pulled all the piping off and found that a small aluminium bolt had somehow (i donno how) had gone into the turbo, there was aluminium everywhere and the bolt looked fairly destroyed.
I removed this bolt, the turbo no longer whines but it doesnt produce boost. (i was mistaken in my 1st post when i said i got boost). So my car drives like....well...shit.
Any ideas? I am going to call turbotech tomorrow and see if they can have a look at it for me. I hope i dont need a new turbo (if so how much are they worth?). In the meantime, do you think its safe to drive thecar with the turbo not boosting?, everything else seems fine.
https://www.sau.com.au/forums/topic/8326-whining-turbo/#findComment-121105
  • 3 weeks later...
dude, even dirt in a turbo compressor housing will **** a turbo. if youve found metal shavings in her, sounds like that bolts munched your compressor wheel to pieces. bad news, turbo's ****ed, good news....good excuse to get rid of that undersized stocker hair dryer and time to get your hands on a trust TD-06!!! personally i wouldnt waste my time rebuilding a standard turbo. they have a rediculous ceramic rear wheel, and chances are if you rebuild the thing, 6 months later it will shit the exhaust wheel anyway. do yourself a favour, look up www.japanesemotorsport.com.au and look at second hand turbo's.
good luck champ
https://www.sau.com.au/forums/topic/8326-whining-turbo/#findComment-139553
