  • Replies 42
I feel sorry for your diff.
there is going to be some serious torque there with the blower.
I havent read the thread but that looks like a VQ45. beutiful engine. That engine put out 206kw at standard in the "gentlemens agreement" it and it was under rated quite a lot.
I put in a guess at 320RWKW. ;)
Sweet mate looks really good. I am in talks with a mate at the moment about putting this model v8 or a lexus v8 in a r33 gtr and make the 4 wheel drive work and add a turbo. Whats the room like around the brake booster and the clutch master cylinder, and how much clearence is there around the exhuasts on both sides???
Good luck, its a bloody good idea!!!
No room for turbos thats for sure, not without body mods and i want this to be 100% street legal so im not going anywhere near that. I built a custom set of headers to turn down really sharp otherwise they would be sitting on the rails.
Be nice to see one in a GTR, lots and lots of fabrication... just not something im bothered with atm... Ive still got my GTR and im trying to get rid of it, it just doesnt interest me as much as this does.
Well it would be a big single turbo so both exhausts would kind of be like a log manifold facing foword, and then run the dump back under the passenger side engine mount or something aroun there. The biggest hastle for me as although its his car I will be doing all the work is cutting and shutting the sump to suit an engine that 1 has a totally different bolt pattern on the bottom then secondly is 2 cylinders shorter in length but wider!!!
My friend has a T-trim on a holden/isuzu rodeo 3.2 6cyl which was stroked to 3.7l and it pushes just over 400rwkw with 25psi.
But oh my god are those things damn loud at just idle!! The BOVs vent constantly and they scream. To the uninitiated it sounds like something is wrong from the loud grinding sound from the supercharger.
Somebody mentioned about your diff and torque. This rodeo had a new ford 9 inch and on its first pass (slicks) it smashed the living daylights out of it. Fitted up a strange full spool and next time out spat out an axle. Fitted in some moser axles and tried again and then it ripped the front of the diff housing off. This is with a six so yeah its gonna make some grunt with your package.
A t-trim at full noise on your motor in an R33 will run deep into the 11's if not a 10 if you can put it down.
I had considered putting a Q45 engine into a CPV35 Skyline but was told they weigh so much more than a VQ35DE engine.
Did you weigh the engine at all as I would be interested to know.
A V35 V8 non supercharged would be a nice daily driver i think.
Cheers
Messy engine WTF??? Looks factory to me?
R34 - wouldn't be much point throwing the V8 into the V35, yes it would push a bit more power, but you may as well just go with forced induction on the VQ35. Even if you're looking at a cost point of view, pick up a lower spec V35 without the VQ35 and throw in a late mode VQ25DET from a stagea :rant:
I like people doing something different like this. Well done. As for the power it will produce, any decent engine with forced induction will produce easily 100rwkW per litre...so it means 450rwkW for this sucker!!!!! GTR drivers start pissing your pants. As for if its a strong enough engine....coated pistons from the factory and 6 bolt bottom end. Thats stronger than your RB26!!!!!
    • The SS button head cap screw on the back? If so, good to know. I presumed it was there for basic assembly and nothing more.
    • Hello, everyone. I'm new to the forum. I have a 1989 Nissan Skyline R32 GTR. I have lost all power to the interior, including AC controls, the gauge cluster, turn signals, and windows. Stuff that still works includes the horn, brake lights, radio, and headlights. All fuses, in the interior and exterior boxes, tested good.  It starts and runs fine, just with no gauge power or anything stated above. No warning lights either. Things that I have tested: - Fusable link tested fine - No other fuses blown - Alternator good - IGN switch tested fine - With my power probe, I can backfeed power through the IGN pin to the plug on the back of the gauge cluster, and everything comes back on.    So my theory is something on the control side that sends the ignition power through the system isn't doing its job, or a wire is broken. (I would think that it is the ignition switch that would do that, but who knows?). The ignition relays don't fire (all relays tested good). So what tells them to fire other than the IGN switch?  I would really appreciate it if someone had some insight on this. I have tons of hours into this; I don't want to give up in defeat! I have the HD wiring diagram, but having all those wires laid out like that on one sheet of paper makes things pretty hard to follow.  Thanks for reading, and thanks for the replies.  Where should I look next? Thanks.
    • Install a MAP sensor pre and post throttle. Best data you could have for NA, then play with the bends and/or air box and see how much of inflection is created at WOT on the plot.
    • And gone to a new home
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
