I had my first dyno run on Sat with my R33 GTS25T. I've had it for 4.5 years and finally got off my but to find out how much power it has. The only mods include a cat back exhaust and pod filter. There was only one run where the boost didn't spike to 9.5 psi (at which point all fuel was cut). On the one good run it managed 196.2 hp at the wheels so around 150kw. People have always said it runs well for a stockish 33 though it still seems a little high. It was done in shoot out mode. I don't know what this means though believe it increases the power.
Is the output normal?
They suggested that I get a front mount, fuel cut defender and boost controller as my first mods. Quoted me $3,000 (which sounds fair I think, I know it depends on brands and models). They indicated that the power at the wheels would increase to around 300 bhp. Does this sound right?
Cheers
https://www.sau.com.au/forums/topic/83301-first-dyno-run-with-stockish-r33/
can you scan in the dyno graph?
if you shop around, youcan get a FMIC including piping for $600-700, and a necent manual boost controller for $50... see the for sale section for more info
i also think a dump/front pipe upgrade will serve you better than a FMIC at this stage
best of luck,
Warren
best of luck,
Warren
I agree with Wazr32, I think completing the rest of the exhaust should be the next thing you should be looking at. BATMBL on these forums sells an awesome dump/front pipe and an excellent hi-flow cat which give you good gains at a top price. I don't think a fuel cut defender is necessary? better off saving the cash for some full (powerfc?) or piggyback (SAFC?) management . If you shop around there are some cheap fmic kits around so keep an eye out.
Just jap are selling front mount for about $550 for SAU members if look in the for sale section. Get the FMIC, put it in your self, it is not hard at all, just need a few tools. some cutting and your set.
When i first got my car i had a cat back exhaust and pod, with a electronic boost controller.
I then put on a BOS import dump pipe and front pipe, and a 3 inch cat, and you could definately feel the power increase. a good dump and front pipe and cat should give you a few more HP.
If your on a budget get a stage 1 GFB boost controller or go all the way with a electronic one. Put the boost up to about 15psi and you will really be feeling the difference.
With thte FMIC, dump, cat and boost contoller, you should be content with the performance for a while.
As many others have said I'd go about getting the rest of the exhaust done first. Then think of going FMIC and Piggyback instead of the fuel cut defender. $3000 does sound abit dear depending on what intercooler and boost controller, but you can get a nice Turbotech from Mark for $35 delivered and FMIC kits (core + piping) for around the $600 mark.
it will be a very special FMIC and FCD to get you over 100hp at the wheels. ;)
Get the cheap cooler, finish the exhaust, get a bleed valve if you don't have one and don't but a FCD they are nasty. if you are on a budget get a jaycar DFA or Apexi SAFC, or if you have the $$ just buy a PFC.
in fact
PFC, dump and front pipe, FMIC and bleed valve will be under $3000 installed and tuned :)
Agree with everyone else. Finish that exhaust first (front/dump/hi flow cat) then think about getting cooler/boost/avcr all at the same time to keep everything running well.
300hpatw? Tell him he's dreaming...
That's about 220rwkw.
Edit: I think I'm having dejavu. I swear I've seen this thread before...
Thanks guys and gals.
I suggested a dump pipe and Power FC. They said a dump pipe could reduce power and instead of PFC they mentioned another brand for around $2.5k fitted and would go on after the other mods. I sort of lost interest at this point.
Also what would be causing the boost spike given that I don't think there is a bleed valve or piggyback computer.
What is shoot out mode.
Cheers
Smurf.
where are you located?
if we know general area, people can recommend the best tuners they know in that city etc.
I'd definitely suggest a different one than the guy you are seeing now.
as suggested.
dump/front and cat from BATMBL
HYBRID cooler kit from Just Jap at SAU prices.
Power FC for R33's are everywhere.. surely they are close to about $1K without the controller.
Tuning - $500
that would be about $2500 max. and would net you about another 50rwkw.
safely.
Cheers
You might lose abit of response down low with the dump pipe, but the top end flow would easily compensate this plus more.
A powerfc if you shop around would be around $1k new (nengun) or cheaper 2nd hand. To install it is free if you know how to use a ratchet and only takes 10 minutes. Tuning, depending on where you go will vary from $500 to $700 for a base tune - also the powerfc can go with all the other mods you do in the future as well, injectors, a/m turbo etc etc.
shootout mode is when they take out some factors in calculating the estimated power your car has, like air temp and some other factors to give you a figure that you can compare with other people done on the same type of dyno that you went on.
Also I would not recommend 15 psi on the standard R33 turbo, as it will most likely blow a ceramic exhaust wheel into your cat. After a FMIC and exhaust you should run 12 psi max if you want to keep your standard turbo for a while.
hope this has pointed you in the right direction, have fun modding :)
once again, thanks for the replies.
i am in newcastle so if you know of any good tuners. there is one place that know skylines inside out i think (Turbo technics) however they want to sell me another type of computer that is around $2.5k. apparently that is normal as it is supposed to be much more advanced than the power fc.
how much power would a power fc plus boost up to 10psi acheive.
and yes i am a lazy bastard.
s out.
i didnt notice any loss in respone when i went from stock to a 3" split dump pipe. in fact i gained power everywhere and the response and wind up time was better
A split dump would be better for low end pressure then a 3", because there would be a higher backpressure off boost due to the wastegate pipe being closed off.
hehe key word being might, a few people i know after fitting them got this result, but after they got a retune they achieved the same result as you. :P
2.5k computer??
Must be a motec or autronic or something else hardcore which you will have no use for.
s out.
You will not see 1rwkw more from using such a hardcore ECU (probably autronic or motec like INASNT suggested) then from the powerfc (providing that the tuner is confident and has good experience with both ecus). Especially at your stage, I can't see why you need to spend that extra on the ECU, with the money you save from getting the powerfc you could get other parts that can make your car EVEN better. But each to your own, if you are confident in your tuners ability and he is confident in that ECU, it would probably be best to do what he recommends - as they say, the ECU is only as good as your tuner.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
