Hi guys
just a quick question. I have an R33 GTS-T 93 Model M-Spec.
I only had this for 4 months & the previous owner told me that the handling of the skyline is hard( pwr steering not kicking) when the rpm is low but when it reached 2 1/2 or above rpm the power steering kicks in & the handling is good, he said its a safety features that all skyline have. So am i a sucker to this? Engine is all good no probs, just the handling is pretty heavy when rpm is low. Any suggestion on how to fix this or is this normal?
Any input would be much appreciated.
cheers
https://www.sau.com.au/forums/topic/83302-help-needed-reg-handlingpwr-steering/
Hi guys
cheers
Load of bullocks!!! Mine seems to be fine at low and high rpm's, ie when parking, no dramas with steering!!!
If you have wide tyres it will get heavier.
What' the problem with heavy steering? ;)
the problem is u have to rev the car abit to turn the steering wheel.
its ok if its on 2000 rpm but from 0 -1000 its hard to turn & u have to rev it abit to be able to turn. i just wanted to see if this is normal to all skyline.
looks like its not.
i got wide wheels, must be the prob :)
I have 235 x 18 and mine, and its not heavy, quite smooth to be honest
What you were told by the pervious owner seems to be rubbish,
Check your fulid levels, and for leaks, also check the tension of the belt running the power stearing pump and its pulley. The belt may be loose or just the wrong size.
may just be something simple and easy to fix.
Rs,
David
Cheers for the reply guys.
i just had a word with my mech, & he said theres no circulation in the power steering fluid at all!!
i just bought a pump, so i hope this would fix it.
cheers for the reply guys. :P
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
