Standard internal Rb20 2 litre that is r32 spec , with a high flow vg30 turbo truck core front mount dump pipe. Some 'mines' ecu a few little mods pod etc, blitz boost controller 290 at the wheels.
I have hit some type of cut, Speed signal cut is the theory at the moment. the dyno graph was heading up still when the power was cut on me. This is on 18 psi. This was at barry's dyno, this arvo.
Enjoy :shake:
https://www.sau.com.au/forums/topic/8331-290-at-the-tred/
Guest KILLER-T
Hey this might sound like a stupid question but at what speed did u make peak power.I'm only asking because i had my car on the same dyno yesterday and the peak power and kmh dont add up
By the way top effort with your power output you have to be happy with 290rwhp well done:uh-huh:
https://www.sau.com.au/forums/topic/8331-290-at-the-tred/#findComment-120468
Guest KILLER-T
Ok it made 304rwhp and 1650 lb torque running 1.08 bar i still didnt get to see my car running 1.25 bar i cant work out why it dont boost as hard on the dyno it must have something to do with load on the engine anyway he didnt do a tune we just put it on the dyno to see how it was running. Barry said he would like to pull a bit of fuel out of the fuel map and then i will see a bit more POWER i will go back in a few weeks once i have some more cash
:thumbsup:
https://www.sau.com.au/forums/topic/8331-290-at-the-tred/#findComment-120488
yeah nice power there guys, specially from the RB20 :thumbsup:
a quick question.. FRIGGIN FOOT-POUNDS for torque.. WTF, i dont get it.. is it a straight forward linear conversion like HP-KW or is it logorithmic?
the reason i ask is on the aston martin website (checking out the vanquish after watching bond last night :mad: ) it says the car has 400ft/lb = 541NM..
linear, that would give your car ~2200NM, where'as a LS1 is only 500NM or so.. i dont get it..
someone care to explain?
Shaun
https://www.sau.com.au/forums/topic/8331-290-at-the-tred/#findComment-120734
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
