Hey guys and girls
its been a while since I posted here. Just bought myself a gorgeous black R34 GTT. I put in a K&N rectangular air filter and took off the induction plastic cover so the car makes very loud induction noise (and so it does and I'm lovin it), however I am just wondering if this is a safe thing to do and will it do any damage to the engine? the engine is a NEO 6 and triptronic transmission.
Thanks in advance =)
https://www.sau.com.au/forums/topic/83332-air-filter-on-r34-gtt/
Hey guys and girls
Do u mean the snorkel? If so, no it won't damage the engine. U just suck in worm air from the engine bay. Might loose a bit of power.
The cover holds the filter in place so it could possibly fall off.
What i did as an experiment was to get a second airbox lid and cut the whole top of it off so that only the edges that clip on to the bottom section of the airbox remain. This holds the air filter securely in place.
Blitz make a metal frame to replace the airbox lid which does the same job they call it the blitz induction cover.
http://www.blitz.co.jp
so basically the only problem with doing this is that the filter may pop out of its nesting?
Mate told me to simply get a couple of clamps and that'll do the job or even glue it, tho thats obviously not as practical lol
I was going to get a full blown pod air filter and clamps and BOV but i'm more satisfied with this sound so as long as its no problem for the engine then i'm more then happy to keep it this way...
Lets see.
1. Hot air being sucked. Cold air is good, hot air is bad.
2. The filter might just jump out, drop onto hot piping, melt cause fire. Fir is bad.
I can't think of any more right now, but dude, seriously, get a pod and heat shield if you are keen on the sound.
Don't just take the top off.
BASS OUT
Lets see.
BASS OUT
Yea seems like hot air is bad but as long as it doesnt cause harm to the engine then who cares if i lose a bit of power? I'm just scared that its bad for the engine thats all... if so then tell me concretely whether it is bad or not so I know.
Also, i washed a KN filter with some blue filter cleaner and i ued a dryer to dry it which is a bad thing stated by K&N website. When you aplply to Oil to the filter, should it dry first or its fine to have it all oily as thath makes more sense....??
I said in a previous post that it is not a good idea to have the air filter not secured. But there must be some merit in my approach of removing the top of the airbox completly so that only the frame that holds the airbox in place remains.
Considering Blitz manufacture something that has exactly the same effect.
The trouble with the standard airbox lid is that the inlet from the "snorkel" is very small, opening up the cover lets air come through the snorkel as per usual as well as any additional airflow into the engine bay.
It it will add a few Kw's on the dyno but I would say that this could be offset by increased heat soak in on road driving conditions.
Just remove the material padding from inside the induction box, this will make it sound a bit louder.
Kepp the lid on though.  BAD for car without the lid.
i asked this question over a yr ago,, but no one had an answer back then,,
so ya,,, will removing the padding under the lid really affect anything?,, Nissan told me it was there to absorb moisture from the rain/water that gets sucked in by the snorkel.
i also thought if i removed it,, there would be more volume above the filter, but then thought there will be more air turbulence,, maybe the padding is also there the reduce the air turbulance before going through the filter,,
so anyone who has removed the padding,, noticed any difference, besides increased induction noise???
Afro
Ok so far I've recieved mixed opinions on this matter. Most seem to think its a bad thing to leave the snorkel off for hot air comes into engine instead of cold, hotter ait makes turbo heat up faster etc so it seems its not the best idea. I put the snorkel back on.
Now, how can I achieve a really noisy WHOOSH sound? blow off valve? pod filter? wat are my options to do this properly and still have the nice suction noise?
Put a pod filter on it, with plastic piping running from a gap in your front bar to the filter. its called cold air intake. or do what blinky said. You'll get a gtreat induction noise, and if the CAI is attached anfd located properly you won't be sucking in hot air.
A blowoff valve is a slightly dfferent noise, and goes off at a different time, e.g when you put your foot on the clutch or back off the accelerator, whereas the filter will only suck when you are accelerating or revving the car.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
