  • Replies 57
Ill take that plastic part above the throtle body.. (the underdash plastic thingy), no cracks or hinges broken? 25$ delivered?
Also ummm $5-10 for the drivers side floor mat?
Are you in sydney?
hey dude, is that the normal r33 door moulding (that has the handle and p/window controls etc in it) or is it carbon fibre?? Looks weird from the pics. Also where are you at?
carbon fibre stick on stuff, came up pretty good came from japan like that.
im in sth east melb, and yes thats the part that all the switches sit in...i have them too
Shong- I may have a snorkel ill check for u tomorrow mate
d00dz - I'd rather sell the parts on ebay than see offer of $5 for an orig carpet come on mate i said REAL offers
Warby - already been offered $50, still taking offers
Noble: You know the rules, post a price for all parts you are selling or this thread will be closed
washer bottles and over flow bottles - $25 each
Interior lights - $20 each
Tail Lights - Offers over $175 the pair..wont seperate
(but have a silver 1 not sure what side yet but $80 for that)
Heater controller unit - $80
R33 manual turbo cluster - $150 (all working great cond)
Bumper $150
R33 LSD turbo diff - Offers $300+
Starter Motor - $150
Dash Surround - Offers $80 so far + postage if someone will beat that and pick up locally i'll be happy to do that
Strut tower bar - $60 pickup or + postage
I'e been forced to put these prices as been told by the authorities of this board guilty as charged, haha plz keep the pm's coming
HEAPS OF OTHER SMALL PARTS U MAY NEED I HAVE
Blitz, what...u mean the ....ooooooh 4 or 5 parts silver parts i had
maybe u should ask forum member "west" since he is a member of the forum pretty sure a paying member..a good friend of mine also and i did buy his car which im sure if you search the threads u will see what it looked like when I bought it.
this is why i had a few silver parts.
thank u for your kind msg
Bumper $150
Hey Noble_Bum,
Do u happen to have the lever mechanism in the boot that operates the small fuel door. Its connected to the lever found below the driver seat that opens the boot and the small fuel door. Kind of hard to describe but its consist of a spring and some plastic bits.
Hey Noble_Bum,
yeah mate sure do was looking at it last night asking myself which poor bugger would need that part, now i found ya...pm me :)
DASH CLUSTER - SOLD :P
rest still for sale and heaps more
Have u got any series 2 parts? I need a series 2 front left fog light cover and maybe the rear parcel shelf, willing to pick up for the right price. Thanks
Bumper $150
Is the R33 LSD turbo diff - Offers $300+ still available is so where are you located
Gunjack
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
