One of my mates is probably going to enter his R33 GTST (S2).
I was going to put mine in but I lose my licence in about a week :)
Either way, I'll come for a look anyway. It'd be good if theres a few Jap cars in it this year.
Think I only saw one last year. A maroon R33 GTST with body kit etc..Anyone here?
I'll be cruising down friday night if i get my car but from J racing by than
I'm guessing everyone else is looking to go on the saturday??
It's $90 to enter at the door on saturday morning probably see what it looks like in the morning and decide to enter or not than
hmmm sounds good... ill be heading down for a look see atleast...
can you enter on arival.?
yeah ya can enter saturday morning at around nine i think it $90 dollars that what I'm thinking about doing
i would just like to say that i went and waited 20mins to get in, then walk for 15mins and saw everything there, I COULD F EN SEE BETTER COMMMONWHORES AND FORDS IN BRADDON ON FRIDAY NIGHT
my comments on the show GAY.
oh the highlight besides seen E's subrau was watching ppl fall off the mach bull, oh and the one really good burnout. It was like a Charnwoood and Qbn had combined to form bogans are us.
Sorry if my commment are harsh but the hole show was talked up to me. Maybe sunday was much much better.
Didnt get there unfortunately.
I wouldve gone today(sunday) if possible.
There was a couple of lines, one was in the go to woah.
A series 2 GTST.
Good to know that there was something different amoungst the bogan-mobils.
Had a quick look today.
Yeah, not great. Saw the two lines on display and a lot of other assorted machines.
Hey gR33ddy, was the white R33 your mate's that we met or what ? It looked familiar.
El Bee
Yep, sure was.
How did he go? It was his first event.
I couldnt get there unfortunately.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
