was just rumaging round on yahoo auctions and came across these fine specimens damn!, i wish they didnt screw the import scheme up!!
just thought i would show y' all
http://216.239.39.104/translate_c?hl=en&ie.../language_tools
https://www.sau.com.au/forums/topic/83394-how-much-do-import-laws-suck/
that first gtr has twin screamer pipes, good son of rajab
Engine system:
HKS Racing 2.8 high deck complete engine
HKS head system STEP Pro V RIFUTA specification HKS STEP Pro IN/EX296
HKS STEP Pro strengthening valve spring set
HKS STEP Pro V Sodium enclosure hollow lightweight valve IN set
HKS STEP Pro V Sodium enclosure hollow lightweight valve EX set
Valve stem seal set :
Full head processing (one set, such as IN/EX port expansion processing, field training positive processing, and escape processing)
HKS GT-3540 twin turbine
HKS Special racing waist gate
WANOFUSUTENRESUUESUTO gate outlet pipe
HKS Head gasket
HKS Strengthening oil pump
Crank damper pulley kit (product made from ATI)
HKS GT intercooler twin entry
HKS Oil air conditioner kit
Top secret GT mass surge tank
NISUMO strengthening engine mount
Auto selection mass oil bread
WANOFU full titanium muffler
Fuel system :
720 cc main injectors x6+440cc addition injectors x6
Twin injectors adapter
Bosch fuel pump x2 (V-Pro control)+SARD in tank
One-off collector tank
ARUZU Stainless steel mesh fuel line
HKS fuel delivery
HKS fuel regulator
The three layer radiator of cooling system aluminum
Billion SUWARUPODDO set
SAMUKO silicone radiator hose
Billion pushing type electric fan x2 (V-Pro control)
Suspension & drive system:
ORINZU FRAG-R Another tank type vehicle high-pitch 30x20-step attenuation adjustment 600 pattern
S&S engineering PIROBORU Front arm
Auto selection Suspension arm PIROKITTO
HKS triple clutch
Varnish MODEFU mount bush
NISMO member bush
Reinforcement & interior :
Two 13-point type WAKUSU 40 pie J 項改 in dash entrainment
Roll bar pillar stop reinforcement processing
Spot increase reinforcement
Auto selection がっ dust support PRO
RECARO PRO racer SP-G FIA official-recognition full bucket seat (driver's seat)
RECARO SP-G (passenger seat)
Electronics :
HKS F-Con V-Pro Gold Ver.3.1
HKS ETC Torque split Controller
HKS A/F knock amplifier
HKS EVC PRO
HKS Turbo timer
Exterior :
Top Secret front bumper
Top Secret front carbon diffuser
NISMO GT carbon bonnet
Top Secret 3D carbon GT-wing
TE37 18 inches wheel of Top Secret limited [ LE ] (product made from RAYS)
NISMO LED GT-tail
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
