r33 door speakers
Guest GR33DyMANGO
hey guys, ive tried searching for other topics on this but cant find any.
what im trying to do (havent attempted yet as i want to make sure i dont destroy my car door) is put new speakers in the side doors of my r33.
how do i get inside to put a new speaker in?
also, where do most of you guys run your amp wires from the deck to the amp in the boot? do you do it:
1) under the door skirt (inside the car) ie to the far left or right of the car just under the carpet.
2) through the middle of the car?
https://www.sau.com.au/forums/topic/8341-r33-door-speakers/
How do you get inside ?
Take the electric windows controller section out (pull it upwards as their are 2 metal clips which are quite hard to release).
Their is a screw in the little holder thing under a plastic cap.
About 4 screws on the bottom of the door and then leaver it out upwards gently.
From their you can see the speakers in the little holders and the rest im sure you know
https://www.sau.com.au/forums/topic/8341-r33-door-speakers/#findComment-120616
It's easiest to run them down the left hand side of the car just under the carpet.
https://www.sau.com.au/forums/topic/8341-r33-door-speakers/#findComment-121203
i put mine flat on the boot floor to the left of the boot, my next amp will go on the right and the subby box in the middle, to mount i got as piece of thin wood (about 2cm thick) and sat it on the floor underneath the carpeting and glued a couple pieces of rubber to it to stop vibration noises and for extra traction to the floow, i then place the carpet back on top and then the amp and then screwed the amp through the carpet into thew wood, worked a charm :) but having the next amp on the right worries me as getting to the spare wheel would be next to impossible :) so im thinking maybe reinforce the back wall to the battery area and mount it in that, hmm decision decisions
but the 6x9 instal;l took the cake i ended up haveing to split my parcel tray in two pieces to get them in, but now they are in they look mad and sound mad :)
https://www.sau.com.au/forums/topic/8341-r33-door-speakers/#findComment-155724
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
