My beemer has them. its a huge convience beaing able to work on the engine without having to worry about bumping the supporting rod.
Just a thought - What if theres a fire in the engine bay and you need to put it out urgently, it would be easier to pop the bonnet open straight away rather than to fiddle around for the stick, wasting precious time till your precious RB gets burnt
hmmm from what i've seen these kits bolt into on of the side guard bolt holes... then attach under the hinge bolts onto the bonnet. not sure if our cars would have enough room for the strut to fold in between it.
wouldn't mind doing it, shouldn't hard.. just gotta have the right fitting on the end.
Check these links. Seems to be a straight bolt on. I'm up for buying these at around $200. but Nengun does not have them.
If people wanna buy these, maybe we could but them together to save on postage?
http://www.tein.co.jp/bondampe.html
http://www.tein.co.jp/bondamp2e.html#photo
i would really like to do this too. Wouldn't know where to start either though. Can someone please do it and put up a diy. :) $400 is a bit much for a bolt on kit really good idea though should have some out standard like that.
as you can see i am lazy i don't wont to figure out how to do it nor do i want to put my bonnet stay up all the time. hehehe :P
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
