Why dont you just get a custom made 3inch system by a exhaust shop instead of paying 3 times more for a jap one???
A cat back system aint rocket science to make
Id love to do that but I was told it may no be any good in the way of making more power...
I have rung around plenty of exhaust shops and all they make is 76mm... Id love to go to a performance exhaust shop and just have one made but Ben has advised me to go jap as he can basically guarentee good power out of it as 76mm isnt big enough...
https://www.sau.com.au/forums/topic/83428-exhaust-shops/#findComment-1512032
FYI
I have a full 3 inch mandral bend system made by trufit exhaust in cheltenham and my cars mades over 300rwkw without any problems.
I am sure they can do a 3.5 inch system also.
Thanks...
Ill give them a call!!!
Id really just be happy with removing the silencer and replacing the hotdog with a decent muffler...
Im not that keep on spending money on something i dont have to....
Thanks again...
https://www.sau.com.au/forums/topic/83428-exhaust-shops/#findComment-1512052
trufit is the guys ice use for most of their exhaust/cooler work
i just spoke to them and thats exactly what they said..
I think ill head down there and have a chat to them and show them my car... The only reason im keep on a jap system is because the tuner said that is what i should get...
Ill see but for the 650-750 he quoted me for a mild steel catback system, I can get a full Stainless Trust system for about $100 more...
decisions, decisions.....
https://www.sau.com.au/forums/topic/83428-exhaust-shops/#findComment-1512098
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
