Hey guys. Umm im not sure how to put this cos i dont know too much about it so i thought id just throw it out there.. I have a t3/t4 (to4e) and its spooling a little too late (5k+) so yeah, i got the car tuned at uas and they suggested changing the exhaust housing on the turbo to allow it to spool a little earlier (4k would be appropriate). Has anyone had experience in this area and would anyone be able to suggest which type of housing would suit my application?? thanks guys.
https://www.sau.com.au/forums/topic/83497-changing-exhaust-housing/
RB20DET? RB25DET?
complete rundown
RB20 det
polished
balanced
strengthened valve springs
had the head machined
copper head gaskets
billett adj cam gears
front mount
pod filter
forged pistons
o-ringed
wallbro 500hp intank pump
GTR injectors
wolf 3D v4 ecu
top mount manifold
catch can
to4e turbo
external wastegate 38mm
turbosmart series2 bov
custom dump
3in exhaust from turbo
i think thats everything
yeah, i understand its not in the league of 'todays' turbos as in response, power pp,lag, but i got it for relatively cheap, and after spending a fair bit on the car i know im kinda bottlenecking it with this turbo..but guys, as we all should know, sometimes our hands are tied and have to make do with what we have..and by any means, bringing on boost 500rms faster is nothing to gawk at. Im just trying to make the most of what i have, thats all, thanks for the response.
here's my educated guess -
Its an RB20 coming on boost at about 5000rpm. Thats gotta be a .86 exhaust housing. Plus the fact the its a dirty old t04e turbo, which will be a roller bearing.
He needs a nice little HKS2530 or something arouind that size, or even a hiflo job of a T3 or t28.
But overall, he needs a turbo with a .63 or smaller exhaust housing and it needs to be a ball bearing turbo.
Now, if you have the money, I'd look at what they have said, a Boost controller with a pneumatic spring or an electronic one to prevent wastegate creep, but I'd also look at either cams or a exhaust cam gear to bring it on earlier again.
My guess it isn't. :mellow:
Clint32 ran a TO4E with a .6 comp cover, 54mm comp wheel, .6 turbine housing and 58mm turbine wheel on his 100,000km' RB20DET.
That didn't get going until 5k.
I've just had a quick look and it made 234rwkw on 16-17psi.
I dont think its that easy. I jumped down an A/R housing size and was surprised i didnt gain more response, sure it got better but he physical difference was huge and the difference in response was about 500-600rpm. The thing could have a huge turbine on it, could be back cut etc, in which case the A/R housing will not do a whole lot.
I could put a 0.48 housing on a T78 and the thing still isnt going to be responsive (not to mention surge)
As for needing to be ball bearing, again i dont agree it needs to be. If i was buying a turbo i would try to make sure it was ball bearing, better durability and improved performance. But ball bearing dont mean squat if the wheels and housings on the turbo aint right. Try my so called truck/plain bearing turbo having the same response as RB20s with 2530/2535s, there is much more to the equation then just the fact that something is plain bearing vs ball bearing etc.
Also i found that housings can get expensive...id live with it for as long as you have to until you can afford a new Garret, they can be had for around $1800, sell the T04E for upwards of $500, rather then spending money on a compromised turbo setup.
LOL..so far two of the better turbo setups on Rb20s on SAU have been plain bearing old school turbos, just well matched ;)
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
