  • Replies 60
Posted Images
Mods:
Power FC
Boost @ 18.5
Garrett GT2560R
Tomei poncam 260/9.15 in/ex
nismo afm's
Sard 700 injectors
full exhaust
Think thats about it
I think its worth the money i spent :D
I will be at WSID today. See what sorta times I can pull
Good to see you got it all done with all the hasles you had .
Good luck at wsid tonight .
https://www.sau.com.au/forums/topic/83532-results-are-in/#findComment-1511437
Thanks guys
Big thanks to Jim @ CRD + Nathan at grey imports for the 'build'
Clutch was a custom 9 puk ceramic from UAS. Beautiful to drive on the street, and hopefully will handle the launches pretty well. Hopefully the gearbox or diff dont break :S
The boost isnt dialed in properly, thanks to my boost controller. So for the first couple of runs I will probably only be running 15 pound (stock actuators). These turbos are way bigger than the gt-ss's and is probably why they take so long to spool. Merli's/kababs car produces similar power at higher boost, but produces it much quicker .....
Once again thanks, and I hope the weather holds up :P
https://www.sau.com.au/forums/topic/83532-results-are-in/#findComment-1511988
How responsive is it compared to stock?
You have basically the same setup im going for except you're using 2560R's whereas im going for the HKS GT-SS's. I'm probably just gonna opt for 2xRB25 AFM's too.
You're running the stock fuel pump minus the low/high resistor right?
Overall a very nice result, grats!
https://www.sau.com.au/forums/topic/83532-results-are-in/#findComment-1512880
