Hi all, I'm currently driving a R33 GTS (N/A) and intended to get a RB26DETT from a R34. Do anyone of you guys know where I can do this upgrade or who can help me with this subject? By the way, approximently how much is needed for the upgrade? It's my 18 months for the R33. Thanks for all the help I can get.
https://www.sau.com.au/forums/topic/83535-gts-upgrade-to-gtr/
Yeh u could call hyperdrive in malaga i think www.hyperdrivems.com.au or any performance workshop.
Dont take this the wrong way but i think ure wasting ure time. *shrugs* its not worth the trouble. Putting an r34 engine in a car doesnt make it an r34. Unless of course its an r34 :mellow:
Oh and id say ud want to be putting aside $10k at least for this conversion.
Biggest problem would be the gearbox, tailshafts, diff, suspension and brakes would all be suited to alot less powerful engine. That means you'd have to replace everything mentioned.
Smells like expensive to me...
I'm thinking of changing engine, suspension, brakes, AWD, and gearbox first. After changing the main parts, then continue with the engine upgrade.....:P Anyway, need some advice because I'm going to break all the process down (DUE TO HIGH COST) but want to know which part can be change first and which must be change along with other parts such as engine?
How bout u change ure mind and buy a GTR straight out :P It gonna be cheaper. and u will get better result.
Sure it would be interesting to see how u go. But on that note its also interesting to watch ppl set themselves on fire. :P
guys, help this bloke out. All he is doin is asking for advice. Contact hyperdrive or c-red or xspeed. They can give you an extimate, but be sitting down when they give ya estimates. Show them your serious and they will no doubt be readi to help you out. try pm gtrken and see what he has too say about it.
Im trying to help him out, i jsut dont believe that its feasible at all.
Things to consider:
Gearbox will not fit must be made to.
Diff will not be easy, there are about a million litte sensors int eh attessa diff such as lateral g sensors, diff sensors, driveshaft sensors the list goes on. While the chassis is the same the wheel base/track is different from the car those sensors are designed to be in so that going to be very interesting.
Brakes and susp are another 3-4k easy.
To top it off the car will be practically uninsurable and u will miss out on gooodies like better seats and instument clusters. It wont look like a GTR on the outside unless u make it in which case it will look like u have riced it up.
But yeh after all that if ure still keen id give the guys above a call. they are all in teh phone book or just google it
Madness, anythings possible if you have an unlimited budget
The 4wd chassis have different front chassis rails to accomodate the front drive shaft access to the front wheel hubs so add in a matter of body building. Supply of parts and fitting I dont think somewhere in the 20k area isnt far fetched. eng box clutch rear cradle brakes efi wire then body wire body mods bulk labour hrs, banannas
as for help booster and jimi giving a splash of realism should be taken as a gift, as for "not having money for gtr etc this conversion would be a "all at once" deal, one hard $ hit. Id want to be clear I wanted to do this before asking for a quote as it may take the supplier a few hrs to write up accuratley
have fun
ok siaw i will put your idea into a more understandable way...
what you want to do is put a 19 yr old young heart into a 90yr old tired body... the young heart will put stress on the rest of the body as all the other parts will not take it...
then you are saying lets change the knee caps and ankles to 19yr olds as well...
it will have problems and break later on...
at the end of the day if it was easy and cheap why wouldnt everyone be driving RB26 GTSt?
i think this is what everyone is trying to say...
also if done half proper you will never be able to sell your car...
Though it may sound like an easy process to install a massive turbo the 2 engines are not the same internally and stuff still has to be changed, no to mention the new ECU.
Im making a guestimate of around $5-7k to install a turbo properly.
I think Jimih suggesting is prolly what u will have to do if u want a turbo. The problem with any conversions or even modifications are the teething problems, alot of this stuff u cant just bolt on and needs litte extras here and there.
