Hmmm.... Yeah... This is on R33 Gtst.
I tried to rewire the bleed valve my car came with and hook up the stock solenoid as a fuel consuption experiment. I hooked up everything to the solenoid and went for a drive. There was no wastegate at all :D The boost just went through the roof. I tried swapping the hoses on the solenoid but to no avail.
This is a diagram of how I did it.
  ___
|   |    --> to wastegate
|   |    -->  -------T-------- --> (cant remember)
|   |                | --> (cant remember)
|___|
Where it says (cant remember) on the diagram:
* One is where the bleed valve is hooked up at the moment
* Another is blocked off at the moment.
I am at work so I cant check any ideas straight away.
Does this sound like the solenoid is gone? Makes sense to me. If the outlet is blocked off then the wastegate would get whatever pressure is in the hose (athmospheric most likely) and will keep boosting. Can I take it apart and fix it?
https://www.sau.com.au/forums/topic/83551-is-the-boost-solenoid-dead/
Mate, I don't know what you're trying to do, but i have a few pointers.
The solenoid itself is quite restrictive, and does not let much air through.
Also, I don't know if you've like hooked it up to power etc, but just try it. Get a bit of vaccuum hosing, and blow on it when the solenoid is open and closed to test it.
id just pick up anorher solinoid dude.
Hence the sig :D I figured people should have trillions of them lying around after fitting aftermarket boost controllers. Blowing into it? Hmmm... I m not sure itll prove anything.
Blowing into the solenoid will test you've plugged it up the "right way" (i.e. for the air flow to be going the right way).
Just blow into the side your intercooler/pressure is coming from and stick your finger over the hole going to your wastegate actuator.
If you can't feel it then it's wrong and try the other way.
  ___
|   |    --> to wastegate
|___|
You have it plumbed the wrong way around. The top fitting on the R33GTST solenoid is the input (boost supply), the bottom fitting is the output (to the wastegate).
:( cheers :)
:D cheers  :(
Yeah, I am pretty sure I tried both ways, but i'll give it another go.
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
